Question about Brother HL-2040 Laser Printer
PAPER LIGHT BLINKING BUT FULL OF PAPER
It's almost like when I put the paper tray back in, it was kind of "hard" to slide,...didn't slide back easily...but it's back in place and full of paper, ..but won't print and light still blinking. I turned off / on / unplugged, checked for paper jams.
  • 7 more comments
  • Anonymous Jun 12, 2008
    paper tray full but wont print, red light flashing constantly, have tried turning off etc but no l;uck
    paper tray full red light blinking will not print
  • Anonymous Jun 16, 2008
    Full of paper, no paper jam, did all the Brother trouble shooting suggestions and changed paper weight. Nothing works. Same problem on two different printers and different computers. ?????????????
  • Anonymous Jun 17, 2008
    Paper light blinking, full of paper, can't find a jam. Won't print - help!
  • mtf63 Jun 20, 2008
    turned power off and back on, took out paper tray, open front cover, held go button.
  • Anonymous Jun 29, 2008
    PAPER LIGHT BLINKING BUT FULL OF PAPER problem, plug unplug, choose printer as main printer
  • Ria kOMputer Oct 06, 2008
    anyone can solve the problem?
  • larryfawell Oct 10, 2008
    Paper pathway is clear, paper light blinking. I note the tray elevation mechanism (L.H.S. inside tray slot) is NOT lifting the feed up. Motor fail? Sensor?
  • most_foolish Oct 13, 2008
    Paper light keeps flashing. Full of paper, no paper jam, turned off and unplugged printer but still blinking. No documents waiting to print, doesn't print when i try to print a document.
It is a paper Jam. Opened everything up and I could not find it. Pulled the toner out and then seperated the toner from its frame and there was a small piece of paper in there.
Posted on Oct 11, 2008
Hi all,
after you've done the routine steps, checking all the spots where paper might be jammed. Reconnect the printer and hold down the go button for around 10secs - it runs a diagnostic test.
c how that works?
Posted on Jul 06, 2008
I had the same problem, and it turned out that there was paper stuck inside the printer. You have to open the front cover and take out the drum. If you go to the Brother website and download the latest drivers, there's a flash animation showing you how to do this, complete with a complete list of troubleshooting all the light indications.
Posted on Jun 22, 2008
Any one can solve the problem. TO Nadfar, Your solution is not matches with the problem. The paper wasn't in the printer.
Posted on Oct 06, 2008
Paper red light blinking. paper is full. What could be wrong? Will not print
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 12, 2010 | Brother HL-2070N Laser Printer
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Paper light blinking, but is full of paper. I turned it off for a day, reloaded the paper. No luck. Can you help.
Mar 26, 2010 | Brother HL-2040 Laser Printer
Status light indicates a paper problem. Paper try is full and no sign of paper stuck inside the printer.
Could be a few things:
Try poking a small screwdriver in the bottom of the tray to manually lift the paper. If that works, you probably have a gear problem - see the post titled, "Status light is red and paper light blinking"
If that doesn't work, put some paper in the MP tray and test print (hit GO button 3x). If that works, you have a problem with the paper pickup and might require some parts (hard to find). Inside the drive unit (frame L) is a little circuit board (relay front PCB). As you try to print, check voltage on pins 1-2, it should cycle to activate a solenoid. If you get a voltage cycle, your solenoid is probably bad - if not, your relay front PCB is probably bad.
Oct 11, 2009 | Brother HL 5250DN Laser Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
Alex,
To isolate the problem, please try the steps below:
Remove and re-insert the paper tray and then click Go.
Take the drum unit out of the machine and put it back in.
Here, I provided you a link that might help you:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_007.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Have a great day!
May 07, 2009 | Brother HL 5250DN Laser Printer
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
Feb 05, 2009 | Brother HL 5250DN Laser Printer
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
Error
1. Verify the following: * There is sufficient paper in the paper tray (at least ten sheets). * The paper tray is not overly full. * The paper stack is touching the back of the paper tray. 2. Slide the paper guides so they fit firmly against the edges of the paper. 3. Press the Resume button to continue printing. good luck :-)
Jan 11, 2006 | HP DeskJet 5652 InkJet Printer
Brother HL-2040 Laser Printer Logo
130 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
