Question about Lexmark X3470 All-In-One InkJet Printer
Odd behavior when printing
When printing a Microsoft Word document, the first attempt at printing it will print the first line of the document. The second attempt at printing it will print the first two lines of the document. The third attempt at printing it will print the first three lines of the document. I stopped after that, not wanting to waste anymore paper. I saved the document in .pdf form and printed it again and it printed normally.
Any ideas if there's a way to fix that sort of thing? I already tried unplugging the printer, rebooting the computer, etc, with no change in behavior.
Thanks in advance!
    Scholar:
  • 50 Answers
FrostPoptart -
An interesting issue. I think the driver may be causing the printer to 'misread' print jobs. I think installing the most current version of your printer's driver should resolve the issue; Rather than use the driver CD, however, use Lexmark's Driver Finder to locate your printer and download the most recent driver:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=x3470&req=:::-1::
I hope this helps!
-thinstatic
Posted on Jun 12, 2008
It keeps randomly printing the following: GET/DevMgmt/DiscoveryTree.xml HTTP 1.1 HOST:
To resolve this behavior, clear the Document Properties check box. To do this, follow these steps:
Word 2007
  1. Click the Microsoft Office Button, and then click Word Options.
  2. In the Printing Options area box, click to clear the Print document properties check box, and then click OK.
Word 2000, 2002 and 2003
  1. On the Tools menu, click Options, and then click the Print tab.
  2. In the Include with document area, click to clear the Document Properties check box, and then click OK.
Nov 05, 2014 | Dell 2335dn Multifunction Laser Printer
My Brother HL-2070N printer won't print Web page
In January 2011 Brother update its drivers for your printer due to a compatibility problem. You haven't advised what operating system you're using but you apparently need to update your drivers.
If you are running Windows 7, you will have to update the drivers either from Microsoft Update or Brother. Click on this link for Brother.
If you are running Windows XP, CLICK HERE
Apr 23, 2012 | Brother HL-2070N Laser Printer
ES 5300 only prints left side
From the program you print the document (MS Word, Acrobat Reader or another one?) go to File and select the Print... or Print Properties option (depending on what program you print from). Then, go through the option and look for an option that says something like "Print Odd Pages" or Print Even Pages". As you're describing the situation, it seems that either the program you use, or the printer control panel, is set to print only odd or only even pages. So you'll need to find this setting and switch to Print All Pages or something along those lines. The labels and wording of these settings depend on the program you want to print from, so expect that you'll need some looking around to do before you find this setting.
Jan 17, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problem printing a microsoft document
Have you tried printing documents in other programs for example in "notepad" or "wordpad?
If the lines do not occur in either of those other progrrams, then the problem may not lie in your printer...
if it does happer, however, you might wanna consider getting a new printer? if much cheaper to get a new one than to get an old one fixed.
Oct 01, 2009 | Microsoft Windows XP Professional for PC
Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Mar 27, 2009 | HP Photosmart C5580 All-In-One InkJet...
Hp deskjet F4280 i have just installed printer onto my computer when i try to print documents or pictures from the web it only prints a very small part of the document, just one or two lines of a 50...
Web page sometimes formated in odd shape/format you may need to print preview to see how it had been formated prior printing the page...this will avoid printing partial informatin and etc...
You may want to check below link to further help if you have any issue with HP F4280
http://etech.maiila.com/hp-deskjet-f4280-all-in-one-printer-driver-manual-software-download-and-troubleshooting-tips
Good luck!..
Nov 08, 2008 | HP Office Equipment & Supplies
Print Odd or even pages only
There is no option in the printer to chose eve or odd pages bout if you print under windows environment you can do that from the able cation example if you use Microsoft world go to file chose printer then chose eve or odd from print comp box
Mar 12, 2008 | HP LaserJet 4050tn Printer
Problem Printing word documents
yes..I agree...that line through the letters sounds like something from the font settings in word...do you have True type fonts selected? The landscape issues sound odd too, but I'm sure it's on the word settings side, not the printer.
check your computers warranty here 4 FREE
Mar 11, 2008 | Dell 922 All-In-One InkJet Printer
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X3470 All-In-One InkJet Printer Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
