Stereo static I have 2 stereos hooked to a computer. It is a 6 channel soundcard and I am using 4 channel setting. I have not had any problem before till I moved Even with the computer volume set to 0, lots of static coming out of the 4 speakers. I can only stop the static by turning volume down on stereos, they both do that. Sometimes, not always, I just touch the metal case on a stereo and the static stops. Thanks for any help one stereo is an Akai and other is a Yamaha
  • ccarlson Jun 21, 2008
    I have a Dell dimension 4700. The speakers constantly emit a crackling or static sound. It sounds like a giger counter detecting radiation.
  • 682 Answers
Shut down all electrical sets around and check if the static goen the problem will be in electrical sets and you have to check it one by one.if it is not solved check your cables for any bad connector -open circuit- short circuit(try with a couple of new cables).-apply a contact cleaner in all sockets and move jack in and out in all sockets(with no power on)
Posted on Jul 15, 2008
How do I set the TV up for satellite TV
The TV will likely require a Satellite TV converter box. The output of the box should be mated to the best matching input of your TV.
That order would be: 1) HDMI, 2) Component (RGB) + Stereo Audio, 3) S-Video 4) Stereo Audio, 5) Composite (Yellow) and Stereo Audio 6) RF (Coaxial).
When selecting 6) RF (Coaxial), you would normally select an output channel on the Sat Box (Ch3 or Ch4) and set the TV tuner to the same channel. A standard coax cable would be installed between the Sat box connected and the TV Ant connector.
All other TV inputs would match the one you used (HDMI, Componet, etc.
Mar 16, 2016 | Televison & Video
Hook up lanzar 4 channel amp, directions say to use single rca cables with y connectors. my stereo has L/R rca outputs for front, rear & sub total of 3 sets =ing 6. amp has total of 4 one rca...
Well personally i would probably use two channels to run all the highs and bridge the other two channels into one mono to run the sub ..
Jun 02, 2011 | Car Audio & Video
I just want to use my old tascam 414 as a mixer so i can run 2 pianos and my computer through my 2 monitors - need help in hooking everything up
I would connect the 2 pianos to 1-2 and 3-4 (assuming you want to use the stereo outputs on the pianos.)
The computer I would connect to the stereo input named 5-6. You will need a 1/4" stereo jack here. Just like the one you find on old headphones.
You could also have the pianos in mono, and use channels 1 and 2, and then connect the computer to 3-4.
Connect your monitor speakers to L-R out.
See page 5 in the manual for a diagram:
Your computer goes where it says "effects" on the diagram.
Hope that helps!
Mar 06, 2011 | Tascam Starter Pack for 4-Track Cassette...
How many speakers and woofer solid audio f2000 2 channel amp can support ?
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Jul 11, 2009 | Solid Audio Formula Series F2000 2-Channel...
    Legend Amp hook up manual.
    Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
    Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
    Run the REM to your stereo power ant. Wire. if available.
    Run the GND to Metal Chassis Ground keep it as short as possible.
    Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
    This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
    There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
    Hope this helps
    Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
    Need specs and wiring options
    • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
    • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
    • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
    • ChannelFlex Crossover
    • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
    • Low-Pass Frequency (120Hz)
    • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
    • High-Current, High-Speed Output Devices
    • High-Efficiency, High-Energy MOS-FET Power Supply
    • Audiophile Grade Component Selection
    • Intelligent 7-Way Discrete Protection Circuitry
    • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
    • High-Level Input - Add on Capability
    • Epoxy Composite PCB
    • 2o.gif Stable Design
    Each 6 1/2" speaker will see 40 Watts
    Each 6"x9" will see 521/2 Watts
    Yes your solution is correct. Front wired in stereo, bridge rear.
    Dec 29, 2008 | Eclipse Car Audio & Video
    Kenwood Receiver connected to my pc
    using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
    or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
    good luck.
    Nov 12, 2008 | Kenwood VR-406 Receiver
    How to hook up a boston acoustic ba7500g speaker
    you can connect the BA7500G speakers to a regular digital coaxial output by using a cable that has an RCA plug on one end and a stereo minijack on the other. However, the pole of the RCA must connect to the tip of the stereo minijack and the shield of the RCA must connect to the middle ring on the stereo minijack. Also set your soundcard to output at 16bit and 48khz.
    Oct 19, 2008 | Acoustic Audio Players & Recorders
    Denon AVR-1804 6.1 Channels Audio Problem
    Make sure the input setting is set to 'Auto' while on those channels and not Analog.
    Jan 18, 2008 | Denon AVR-1804 Receiver
    3 of 5 speakers not working.
    Go into your computer audio system and make sure you are on you are not set on stereo
    Oct 20, 2007 | Logitech X-530 Computer Speakers
    106 people viewed this question
