Question about Intel Motherboard
Help me pls
How can i update Bios for P4vxasd..
First..if i open power ..there start on working...i mean there have appear ..bios checksum error and ...now nothing appear how can i do ..pls help me ..
  • Banyar Jun 12, 2008
    i don't have floopy drive and start-up disk bro....
    if i can do how i want to know...
    the place i arrive is very poor to buy that thngs..pls help me
  • 70 Answers
First you need to have a Floppy Drive installed on you computer, then Second you need a stat-up disk.
You also need to download the BIOS File Update on this link
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?
CategoryID=1&Typeid=2&detailid=59&DetailName=BIOS&DetailDesc=P4VXASD(V1.3)
&MenuID=39&LanID=9
Then you also need to download an AMI FLASH Utility Software to upload the BIOS FILE Update on your motherboard, you can use the link stated on that link above.
If this procedure solves your problem, please spare a little time to rate my solution.
-mrsolution
Posted on Jun 12, 2008
  • steve quelnan
    steve quelnan Jun 12, 2008
    You need a floppy drive and a startup disk, because that is the only thing that the motherboard will read (i think) in that kind of problem. But ok if you really dont have that items, try this disconnect all the motherboard connectors, like IDE, SATA, & POWERSUPPLY, also temporarily remove all hardware cards connected on motherboard like, Modem, LAN, Video Card, etc. Then you also need to remove the CMOS Battery, its like a silver coin on your motherboard, and also the Processor & Memory. Simple NO DEVICE MUST BE CONNECTED on your motherboard. Then just let your motherboard rest for alteast 1hr or 2hrs. After that, then assemble again your Computer. Be sure you know how to put it back together.
    -mrsolution
Hello, Although I changed the CMOS battery and I'm flashing the bios with awd865 km4m2803.bin and I am clear the CMOS then I restart my pc but the error "CMOS checksum error" exists Again, my...
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS
BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps
Apr 29, 2011 | EliteGroup KM400-M2 Motherboard
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Checksum error in bios
the on-board battery may be bad-try replacing it.
Jan 12, 2009 | Computers & Internet
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
I need help
-mrsolution
Jun 12, 2008 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
Computer problem
the problems happens when u power off the system directly,
this is located in the CMOS of the motherboard not in HDD
Feb 19, 2008 | Computers & Internet
My ecs p4vmm2 cannot open to windows
you must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Sep 11, 2007 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
