Re: rca drc277, using the standard av cable i get no audio. switched to the other tv in case, it's the player. returned/exchanged one already and have the same problem with the second one.
  • Anonymous Jul 12, 2008
    I also bought this RCA dvd player model DRC277 and when I hook it up via HDMI there is no sound. I tried all of the sound options I can find in the menus but nothing works. I have it hooked up though a HDMI switch but that seems to not be the problem because my Playstation 3 works fine through it with sound and all.
I got the same model twice, the first time it just keep opening the tray. The second time it play the dvd previews once it got to the root menu it froze, had to open it up after several trys to eject the dvd (rental dvd). I would not recoment it.
Posted on Jul 28, 2008
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Dvd hookup
It sounds that you are connected the TV with DVD player Via AV cable. In this case, no RF channels won't go. You have to select its AV option. Check it. Refer the user manual for TV.
Aug 12, 2013 | RCA F19251GY 19" TV
I have sound but no video
The Television is looking for SVIDEO, which is a separate standard. Since SVIDEO does not provide Audio, it uses RCA audio cables. Try switching to a Video in or AV IN setting.
Oct 22, 2012 | GE 32GT740 32" TV
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
What kind of AV cable is used for the Kawasaki PVS10921 Portable DVD Player? I have the player itself, but lost the AV cable to connect the player to my TV, and I've been unsuccessful in my attempts to...
The cable supplied with the player splits the audio feed from a single audio jack to dual RCA jacks for connection to a standard VCR or TV. The video appears to be a straight RCA to RCA type connection where a standard cable can be used.
See the users manual here:
http://www.1800customersupport.com/productdocuments/PVS10921%20Product%20Manual.pdf
Dan
Aug 26, 2010 | kawasaki PVS-10921 Portable DVD Player
Why won't my TV pick up my DVD connection? The player works fine, but the TV isn't showing the picture. What do I do?
Are you sure you are selecting the Audio Visual Input? The wire are color to color Yellow to Yellow, Red to Red, White to White. Ensure you have it in the correct Video IN and Audio IN and have selected and the correct AV input on the TV.
Feb 06, 2010 | RCA DRC277 DVD Player
Can not use Vizio or Direct TV remote to control RCA DRC277 DVD
I took this piece of junk back to Target and got my money back.
Jun 26, 2009 | RCA DRC277 DVD Player
RCA DRC277-A, No sound when played through a Samsung HDTV using the HDMI chord. Chord and TV seem to check out fine. Tried all buttons and menus I could find. Have set sound to PCM, etc.
There might be a setting in your tv's audio menu to enable your audio source, which is now hdmi (vs. the rca-type red and white audio cables). Once you select the type of audio you are using, the audio, you should hopefully be able to get sound from your dvd player now.
May 31, 2009 | RCA DRC277 DVD Player
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
