FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
Compac dv 2000 laptop
posted by civ edagal on Jun 12, 2008
How would i know if my system board is not working
Comment by civ edagal, posted on Jun 12, 2008
my laptop dv2000 switch on but doesnt boot i dont see anything on the screan
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by thinstatic, posted on Jun 12, 2008
Civ -
There are a lot of variables in that. Is your system having a specific problem? I do a lot of laptop repair, and its been my experience that most issues with laptops have to do with components /other/ than the motherboard. Please send me more info!
-thinstatic
Best Solution
Thanks for Trying (70)
AllyMcbeel
Rank:Wiz Wiz
Rating: 81%, 26 votes
first you have to know what is goin on with your laptop, is it starting up to the bios? or continously restarting, or rebooting or totally not statring at all. please specify what exactly happened to your pc to be able to know what if your board is not working at all
have a nice day
ally
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 13, 2008
Not Rated (0)
thinstatic
Rank:Wiz Wiz
Rating: 86%, 15 votes
Civ -
Okay. somewhere on the back or side of your laptop should be a standard VGA connector. Plug a regular computer screen in to that connector, turn the screen on, and start up your laptop. On your laptop's keyboard, in the lower left hand corner, should be a Function key, probably labeled 'Fn'; On one of the number keys along the top of the keyboard should be the Display Toggle, a key with two computer screen icons. Hold the Function key, and press the Display Toggle key - This should switch between the laptop's LCD and the computer monitor. If nothing comes up on the monitor, make sure the monitor is connected and on, that the laptop is on, and press the two keys two or three more times.
If nothing displays on either screen, either you have a bad memory stick, a bad hard drive, or, at worst, a bad motherboard(cheapest repair being memory, most expensive is the motherboard.)
If there is no display on the laptop's LCD, but the regular computer monitor shows your normal startup/windows screens, that tells you that either the LCD Inverter board is bad, or the LCD itsself is bad.
Hope this helps ya!
-Haden
This Problem Also Relates To: AOpen (MX4SGI4DN2PRE) Motherboard ASUS M2N-MX Motherboard ASUS P5W DH Deluxe Motherboard ASUS P5N-E SLI Motherboard ASUS (P4BP-MX) Motherboard ASUS 865G (MBAS-P4P800VM) Motherboard ASUS A7S333 Motherboard
Can you Help with these Motherboards problems?
Mercury P4VM800M7 Motherboard
motherborad drivers
hi I have lost my... Answer This...
Panasonic UB-5315 Whiteboard Motherboard
Cannot capture info from...
When I plug in the UB-5315, I... Answer This...
PC Chips M810DLU (M810DLUV75C) Motherboard
BOOT falilure after RAM...
history: every time when the... Answer This...
After I installed a new memory...
When I replaced it with an old... Answer This...
Intel D845GVSR Motherboard
Emachine t3958/d845gvsr mobo
Having problems getting a... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
