Question about Cobra 29 LTD CB Radio
John Q president cb
How do you calibrate a John Q president cb??
    Brigadier General:
  • 6,966 Answers
If by calibration, you are referring to the check if your antenna is tuned, below information may be of help.
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjusting
the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
SWR METER. Measures standing wave ratio of the antenna system.
Used to properly adjust the length of the antenna and to monitor the
quality of the coaxial cable and all RF electrical connections. If there is any
degradation whatsoever in any of the foregoing, due to humidity, salt
spray, vibration or corrosion, the SWR meter reading will rise, thereby
indicating that a problem exists.
To calibrate, switch to the "CAL" position, transmit by pressing the mike
switch, and adjust the SWR control to the "CAL" mark on the meter; then
switch to "SWR" position for the SWR measurement.
If however you are referring to the internal calibration or tuning of the transmit and receive sections, you would need several instruments/equipment such as RF generator (0-30Mhz with 1Khx modulation), Spectrum Analyzer, Modulation Scope, Dummy Loaded Wattmeter, Frequency Meter and some others. These of course are not readily available to the average user.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
Why was presedent Jackson infriated by the chiefs disition
OK, let's try this in English and see what Google makes of your question. To Google well, you have to be able to spell well.
Why was President Jackson infuriated by the Chief's decision?
And Google does know?
John Marshall has made his decision, now let him enforce it. - PBS
www.pbs.org/wnet/supremecourt/antebellum/history2.html
  1. Cached
  2. Similar
Georgia (1832), Marshall infuriated Jackson by insisting that Georgia laws that ... Under Chief Justice Roger Taney's leadership, the Court in the Dred Scott case (1857) ... President Andrew Jackson ignored the Court's decision in Worcester v.
Worcester v. Georgia (1832) ' New Georgia Encyclopedia
www.georgiaencyclopedia.org/articles/government-politics/worcester-v-georgia-1832
  1. Cached
  2. Similar
An infuriated Georgia legislature responded by purporting to extend its jurisdiction ... Although Chief Justice John Marshall ruled in Cherokee Nation v. ... President Jackson did not enforce the decision against the state and instead called on ...
[PDF]Wordly Wise KEY Lesson 1
www.oakparkusd.org/cms/lib5/CA01000794/.../Wordly%20Wise%20printable.pdf
  1. Cached
  2. Similar
Apr 18, 2012 - (c-a) If you infuriate someone, you make that person very angry. 2. (d-a) A sham ... President Jackson was infuriated by the chief justice's opinion because ... Authority is used to mean "the right to make decisions or take action.
The Cherokee Victory :: essays research papers - Free Essays
www.123helpme.com/view.asp?id=89131
  1. Similar
Through the Indian Removal act in 1830 President Andrew Jackson ... rulings delayed this for the Cherokee Nation, and infuriated President Jackson. ... to find a way around this decision and had three minor Cherokee chief's sign the "Treaty ...
Free Essays on Why Was Andrew Jackson Infuriated With The Chief ...
https://www.cyberessays.com/.../why-was-andrew-jackson-infuriated-with-the-chief-ju...
  1. Cached
Essays on Why Was Andrew Jackson Infuriated With The Chief Justice for ... over Cherokee territory but the ruling was ignored by the state and by Jackson .
American Frontier - Page 53 - Google Books Result
https://books.google.ca/books?isbn=0787705292 Tim McNeese - 2002 - ‎History In 1825, President James Monroe ordered American agents to obtain a land cession ... Georgia, the Court, led by Chief Justice John Marshall, determined that the ... This decision infuriated the governor of Georgia.Also, the president of the United States, Andrew Jackson, refused to abide by the Supreme Court decision.
Conflict and Change in the West: The American Frontier
https://books.google.ca/books?isbn=0787741558 Tim McNeese - 2002 - ‎Education In 1825, President James Monroe ordered American agents to obtain a land cession ... Georgia, the Court, led by Chief Justice John Marshall, determined that the ... This decision infuriated the governor of Georgia.Also, the president of the United States, Andrew Jackson, refused to abide by the Supreme Court decision.
Google
Jan 06, 2017 | Miscellaneous
President p-400 base. Where can I get a manual?
http://www.manualslib.com/manual/800877/President-P400.html#manual
Mar 11, 2016 | Uniden Radio Communications
Uniden president ssb base no transmit and no receive how to fix
Have the mic checked first to make sure wired correctly and or wires not broken where connect to plug----also check to see if same on SSB and Am.
President what? Madison, Lincoln etc.
Apr 23, 2012 | Radio Communications
I need to put a 4 pin plug on a ds-602 mic to suit a president mckinley,could any help please
hi there pin1=audio/mic
pin2=ground/braid wire
pin3=RX/recieve
pin4=ground/black wire
pin5=TX/transmit
hope this is useful
Dec 02, 2011 | Radio Communications
I need the schematics for a Uniden President Washingtom cb radio
I have the schematic, in a pdf form. Just need a way to send it to you. email/ftp/ send me a self address envelope ill print it out its not very big.
Nov 27, 2011 | Uniden PC78ELITE 40-Channels Base CB Radio
I have a president zachary t base station cb radio that squeals on ac power. what can i do to stop it
Hi coonhunter,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Could I ask you to re-post, your question falls under something
different. I have BASE is that correct?
Jan 02, 2011 | Uniden PC78ELITE 40-Channels Base CB Radio
Whats wrong when I key my mike the needle doesn't hardly move?
Hi,my name is John. Welcome to FixYa. Check your SWR, if it is ok, then it probably is nothing wrong with it, just needs to be calibrated. Thanks for choosing FixYa...John
Nov 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
Wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
Jul 23, 2009 | Magnum DeltaForce CB Radio
Cobra 29 LTD CB Radio Logo
907 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
