I'm configuring a cisco 2501 and I have one problem.
everything seems to work ok, except about 15 seconds after booting the
router I get a message that line protocol is down (that 's serial 0 where
T1 is connected.) I need to get this line up and running today, so if
anyone could help me, it's highly appreciated.
Thanks
Kris Kedzierski
kked @comports.com
Activetech Online
To unsubscribe from this list, send 'unsubscribe' in the body of an e-mail
to 'inet-access-requ @mailinglists.org'
Rating: 0%, 0 votes
this week with one. Our original CSU/DSU for a fractional line died,
so I hooked up a spare Cray RouterMate CSU/DSU, which worked fine. We
ordered a new Motorola FT100S as a replacement.
Using the included DB-25<->V.35 adapter that came with the FT100S, I
hooked it up to our Portmaster 2ER with its DB-25->V.35 cable, and
set it up (4 x 64k channels, loop timing, b8zs, esf)... no go. I double-
checked everything against the Cray configuration, still no go. I put
the FT100S into DTE local loopback, turned on debugging on the Portmaster,
but never saw any "(LMI) Apparent loop" messages.
I find it hard to believe it is our cables, since they are the exact same
ones we used with the Cray CSU/DSU, and worked perfectly for a few days.
Am I missing something here, or is this brand new Motorola FUBARed?
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
eliminate the following:
o mismatched encapsulation
o improper serial cabling - e.g. Motorola's FT100S uses a proprietary
25-pin v.35 connection - often a standard DB25-RS530 adaptor is
mistakenly used as a substitute for the proprietary adaptor
o faulty DTE timing - if the cable connecting the router and DSU is
long, it may be necessary to set the DSU to receive DTE timing from the
router
Brian
Brian Wallingford
Network Operations Manager
Meganet Communications, TCIx, Inc.
Rating: 0%, 0 votes
encapsulation is set to pp
as for the cabling I have the original Cisco cabling connected to a Digital
Link Prelude Encore CSU/DSU
Would any screens from the config help?
Thanks
Kris Kedzierski
kked @comports.com
Activetech Online
Thanks
Kris Kedzierski
kked @comports.com
Activetech Online
Rating: 0%, 0 votes
other end set for encap mode and have you confirmed that the T1 or whatever
is up and working
IEAK prepared for you
and/or Netscape
CD's made for ISP
717 842-7372
Larger quantities also available
sys_ad @teisprint.com
Send 'unsubscribe' in the body to 'list-requ @inet-access.net' to leave.
Eat sushi frequently. i @inet-access.net is the human contact address.
Rating: 0%, 0 votes
Brian Wallingford
Post a New problem for Motorola 6 ft. V.35 Cable
Email this problem
