Question about Sony KDF-E60A20 60 in. LCD HDTV
Thermal fuse Please tell me where is the thermal fuse located. Also, do you really just connect one end of the fuse? How does this complete a circuit and fix the set?
Someone said it is the thermal sensor.
Posted on Jun 18, 2008
Our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
see this causes and fix it. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 27, 2012 | LG DLE2532W Electric Dryer
My belling 335wh oven or back hotplate doesnt work
The thermal fuse in the back of the oven is faulty. If you have a multimeter, select OHMS and check across both terminals of the fuse will show it to be open-circuit. You can compare with the grill thermal fuse. Change the oven thermal fuse and it should be ok. While you're checking this, may be you can solve my problem. both your oven elements will have one terminal connecte together by a grey wire then both earths connected by green/yellow wire, the remaining terminal hopefully has a yellow wire, can you tell me where the other end is connected to.
Jun 28, 2012 | Belling 335 Electric Kitchen Range
Where is the fuse on a alantis dryer
Instructions :
Unplug the dryer from its electrical outlet or flip the circuit breaker switch that corresponds to the appliance to the "Off" position.
Open the door of your Maytag Atlantis dryer and remove the four screws on the inside lip of the door opening. Set the removed screws aside.
Grasp the sides of the front panel and pull it toward you to separate it from the dryer cabinet. Lift the panel straight up to clear the two retaining clips on the bottom of the cabinet. Set the removed front panel to the side.
Locate the thermal fuse on the blower housing cover. Look for a thin, plastic strip approximately 1 inch long that has two wires attached to it.
Pull on the locking clips with needlenose pliers to disconnect them from the thermal fuse. Remove the screw that secures the thermal fuse to the blower housing cover. Discard the thermal fuse, but reserve the screw.
Line up the screw hole in the replacement thermal fuse with the screw hole on the blower housing cover. Reinsert and tighten the reserved screw to install the new thermal fuse. Clip one of the two wires to each end of the thermal fuse to complete the installation process.
Honda Parts.
May 28, 2012 | Dryers
Will not heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access them by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6) - This is a replacement kit. Includes Item 15 when ordering.
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If your dryer is NOT configured this way, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening) and let me know.
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of heat related problems:
1. Blown Thermal Cut-Out.
2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers.
3. Bad power cord, causing 1/2 the input voltage to be missing.
4. Blown heating element.
Read through all the information provided and let me know if you have any questions. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 23, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer not heating up
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
Apr 22, 2010 | Whirlpool LER4634J Electric Dryer
How many thermostats are there and where are they located?
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
Thermal Cut-Out (Item 9)
Internal-Bias Thermostat (Item 8)
Thermal Fuse (Item 7)
If you have any questions, or need further assistance, please post back and let me know. I hope you find this information helpful.
Mar 21, 2010 | Whirlpool WED5700S Electric Dryer
On the Kenmore series 90 electric dryer, where is the thermal fuse located.
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Jan 06, 2010 | Kenmore 73952 Gas Dryer
Where are fuses located on kenmore dryer part#3394996 one of the connecters on heating element sparked and im thinking it blowed a fuse
Dryers have a thermal fuse... it's a ceramic 2-3 inch long resin-filled fuse with wires attached at both ends... near the motor...inside the dryer..
The other fuse would be your house circuit breaker panel. Check the thermal fuse..
Dec 08, 2009 | Kenmore Dryers
Problem with steam
I'll take the machine if you are throwing it away:) You have a blown fuse. There are 2 fuses inside the mahine. Uplug the mahine, Pull the top of and locate both fuses. Connect a wire going from one end to the other of the fuse. This will temporarily short circuit the fuse. Now plug the machine in, and test it out. If it works, than that is obviously the bad fuse. If not, try the exact same procedure on the other fuse. My thermal fuse went out and it only set me back $1.98 to fix. Good Luck!
Jan 05, 2009 | Gaggia Baby Espresso Machine
Whirlpool electric dryer
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a generic answer that may assist you in gaining a diagnosis. Fix the NO HEAT symptom and your other complaints should be resolved also.
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward
Jun 21, 2008 | Dryers
Sony KDF-E60A20 60 in. LCD HDTV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
