Question about Cobra 29 LTD CB Radio
Cobra 29 LTD cb radio
My radio does not key up or receive anything but the swr meter works. What should i do??
  • Hayden Dickson
    Hayden Dickson Mar 14, 2014
    I would have already Ebayed it :) Barring that, check the pa/cb switch and the wx/cb switch. I generally just rip off the wires and wire them direct and disable the switch. It ain't an old cobra and we ain't in Kansas anymore. These must join the "exports" as the worst radios on the planet! Now if actually talking was your object, buy yourself a $2 Pinto off Ebay. Those will last another 50 years :)
    Scholar:
  • 66 Answers
Strange problem indeed, this is why I don't like Cobra radios, they're no good. But try adjusting the receive gain on the radio, if that doesn't work, you might need to check the antenna, check if it is connected properly, or if the antenna actually works. Honestly though, if you want a solid performance radio, go Galaxy or Uniden, no Cobra. I worked with radios for years, and Cobra has failed to meet my expectations for a good radio, they may have a lot of features, but they have no reliability.
Sorry :(
Anyway, I hope this helps somewhat.
Posted on Jul 01, 2008
Red lights come on tx n rx and antenna come on when I key up the cb radio and the swr meter doesn't move
if a mod has been done to the cobra 29 (all 29,s)the light will come on just find vr6 audio the radio as it comes on adjust vr6 untill it goes away,,,,always trust your watt meter(s.w.r scale)over the flashing light its really easy to do it beats paying a shop $10-$15
Jan 13, 2013 | Cobra 29 LTD CB Radio
How to match a antenna to a cobra 29 LTD Classic
You are actually tuning the antenna to the vehicle it is mounted on here are some very good resources. http://www.rightchannelradios.com/pages/cb-antenna-tuning-guide-pv-c0-61.htmlhttp://www.wilsonantenna.com/swr.php
Be aware that if your radio has been modified it may produce a dirt signal that an swr meter may read as reflected power. In this case it may be more accurate set with a unmodified radio also if your radio is setup for a linear it may have a deadkey to low for the swr meter to calibrate correctly.
Hope this was of help.
Nov 26, 2011 | Cobra 29 LTD CB Radio
I have a Cobra CB Radio and was wondering if I have it on SRF or SWR or CAL
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjust-
ing the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
You will want to operate on S/RF position.
Jul 14, 2011 | Cobra 29 LTD CB Radio
I want to calibrate my cobra 29 NW Ltd. Classic
Calibrate For SWR (Standing Wave Ratio) http://www.cbtricks.com/radios/cobra/29ltd_bt/graphics/cobra_29ltd_bt_om.pdf
The CAL is only to calibrate meter for a swr check of you antenna system it does not calibrate radio.
Jan 11, 2011 | Cobra 29 LTD CB Radio
Need instructions on how to swr my cobra 29 ltd bluetooth
You insert an SWR meter in the antenna line, usually one end goes into the Antenna OUT socket, and the Antenna plugs into the SWR meter, you then tune you antenna coupler, inductor, & final PA, in the final stage, until you achieve a 1:1 SWR reading, this is however quite hard to achieve, so simply tune for the closest 1:1 SWR that you can achieve.
Feb 22, 2010 | Cobra 29 LTD CB Radio
Not sure how to use the swr meter on my cobra nw
The SWR meter connect between your antenna and your rig,
So the Out of the rig, goes into the SWR meter, and the antenna plugs into the SWR meter.
Jan 19, 2010 | Cobra 29 LTD CB Radio
Cobra 29 chrome
you could have a bad soilder but probably your voltage regulator went out.
Dec 15, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic needle doesn't work correctly
Don't worry about the meter in the radio. They are only close to actual reading any way. Just get an external meter. you are better off in the long run, and you don't have to mess with anything inside the radio if you don't know what your doing.
If you must have the meter working correctly, then take it to a truck stop CB shop, or any other cb shop and have it aligned. It should cost about $30. There is equipment needed to align a radio properly and the cost for it far exceeds what an external meter, or having a cb shop align the radio.
Mar 10, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
222 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
