Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Flickering screen with semi-circular middle whitish flicker and static sound
Have a 3-year old WD-52525.
3 days ago, picture was "scrolling" quickly, but sound was OK.
Tonight, picture is flickering (no video) with a ovoid / semi-circular whitish pattern almost like a galaxy seen from the side. Sound is still staticky.
Initially, online menu was OK but now it too is affected by the static and bad picture.
Tried all inputs (Xbox, DVD, cable) and same problem, so it's not the cable only.
any ideas? Got the 4-year extended service warranty from Best Buy so that's my next resort. Have not tried calling Mitsu customer service yet.
  • Mitsubishi Master
  • 8,617 Answers
Use your warranty, as most warranties are vioded if you open the set up.
Posted on Jun 12, 2008
I have a Tevion 32 inch LCD (Model LCD3210id ), purchased from Aldi stores about 4 years ago. The screen has started flickering and it is making a slight crackling sound from the back. One, has anyon
Those sounds would be either your power converter/supply inside the TC or/and faulty cabling inside that has been worn out resulting in noises and flickering.
Dec 24, 2012 | Televison & Video
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52525 no picture or sound
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Same problem - loss of picture with green bars flickering
We contacted Mitsu today in Irvine. Sounds to us like they're aware of a widespread problem with this model. Told us to get a Mitsu Tech to diagnose and fax to them the outcome and someone would contact us back within two days. Seems like so many are having the same problem and all about 2.5 to 3 yrs. old. I paid $3,500.00 for mine. I'm not going down without a fight with Mitsubishi. Thought they were #1 in the Big Screen world. CLASS ACTION LAWSUIT OR RECALL BY Mitsu should be in order....They know there is a problem with the power supply module.
Jan 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 flickering blue screen
it sounds like the light engine has failed..since it is expensive it would be a good idea to have a factory trained tech take a look
Nov 25, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
