Question about KitchenAid KESC307 Electric Kitchen Range
KitchenAid Electric Range Model KESC307HB56
Following cleaning, the oven does not respond properly to the selected temperature. When we select a temperature, say 400, a temperature of 77 is displayed. However, the oven does heat up, if anything it goes beyond the temeperature we want.
  • 413 Answers
Electronic control has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method next time.
Posted on Jun 13, 2008
Motor working sound when our new Frigidaire electric range is heating to selected temperature. Is this normal?
some fan assisted ovens turn on the fan to get up to temperature, its an energy efficiency thing, also mean pre heat is quicker. if you need more info on this unit here is web page
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=LGEF3045KF
hope this helps you.
Jun 11, 2017 | Frigidaire Kitchen Ranges
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
My kitchenaid range KESC307HBS door will not unlock code F5 E3
Hi ad welcome to FixYa, I am Kelly
Here is the service manual:
http://appliancedigest.com/index.php?/files/file/242-whirlpool-kac-34-kitchenaid-self-cleaning-slide-in-electric-range-service-manual You have to join the site to get the manual but of all sites this one is a gold mine of information. I am sending this link now and will respond again after my almost 3 hour manual download of the manual. I have to read the manaul myself before responding. My intial thoughts are the following: Possible door lock failure, an oven sensor has failed or a high limit thermostat has failed. I will resond with the code F5 E3 data after the manual completes. Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
Clean mode
The door lock switch may be stuck down. is there a door lock light on the panel? Otherwise I would guess your control is bad.
Oct 29, 2007 | GE Spectra JBP78 Electric Kitchen Range
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
263 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
