Question about Actiontec GT701WG Router (actiongt701wg)
Xbox360 mtu prb.
Everything else confirms but says MTU failed what is it, and how do i correct it? thanks
D-man
  • Anonymous Jan 03, 2009
    WHAT IS THE CODE THING YOU NEED FOR THE SECOND STEP
    IN SETTING UP XBOX LIVE
    Problem Solver:
  • 18 Answers
Maximum Transmission Unit (MTU). Go to the following page and follow every steps in it plus the highlighted text since they provide valuable information to your problem.
http://www.dslreports.com/faq/7120
Posted on Jun 12, 2008
MTU settings
where do i go to change the mtu settin on a comtrend ct-5364a
Sep 11, 2009 | Computers & Internet
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
Hi im new and im trying 2 fix my mtu settings 4 my xbox360 but do
the mtu may be because xbox live is being updated, id wait 24 hours and if it still doesnt work contact your isp(internet service provider).
Jul 12, 2009 | Microsoft Xbox 360 Console
My x box says change mtu to auto or 1364 how do i do this
My MTU is at 1500 and I get the same message. I don't think it's up yet.
Jun 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
MTU fail
ok well I found a fix but it may not be simple. anyway, i got my xbox360 to work off of my girlfriends laptop by feeding internet to the laptop from the cable modem via usb and then from the laptop to the xbox360 via ethernet. just right click usb connection in network connections and click sharing tab, then activate sharing and tell it to share connection with lan connection... you can also share through wireless if your xbox is wireless. I tried running all this through a dsl wireless router and a basic hub and both of them gave ip address and mtu errors... good luck
Nov 10, 2008 | Microsoft Xbox 360 Console
Connection problems
MTU stands for "Maximum Transmission Connection". Some routers and/or network gateways are incompatible with Xbox LIVE, while others may be compatible but merely need to have a setting changed. If you compare your router to the list of routers at the following web address, you can confirm whether or not your hardware has been confirmed as compatible with Xbox LIVE by Microsoft:
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Whether or not your hardware is listed as compatible, it would still be a good idea to check your instruction manual for the hardware you are using and see how (if possible) to change the MTU settings. Microsoft suggests that the MTU setting should be 1364. Using untested hardware or hardware not listed as compatible may still work, however, future updates to LIVE may suddenly make your hardware incompatible, as updates to LIVE and the Xbox console are made to work with the specifications of tested and listed compatible routers and gateways.
Aug 13, 2008 | Microsoft Xbox 360 Console
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
MTU failing for Xbox live
Hi
I am afraid Dell 2350 Wireless Router is not Xbox LIVE Certified.
Check Microsoft Knowledge Base ID: 908882 - http://support.microsoft.com/kb/908882/
And
Xbox Live Compatible logo - http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Mike
Mar 17, 2008 | Dell Wireless 2350 Router
Xbox360 connection problems
It appears we need to buy a different router. There is no way to change the MTU on the Blitzz BWA711
Nov 01, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Westell 6100 problems
we had the same issue. Here is how we fixed it. I had the xbox 360 plugged directly into the westell 6100 modem via ethernet cable. the mtu test failed everytime. I was extremely frustrated and called microsoft and verizon (dsl) about 10 times each and they kept giving me the wrong solution. (get a new modem, get a new server, pay us money and we'll figure it out etc...) Here is what a man at microsoft told me to do and finally it worked. Power cycle your equipment (unplug modem and xbox 360 for 30 sec.) then, plug in modem first and wait until all lights are back on. Then plug in xbox and run test. In my case mtu failed again. I was then instructed to go to my dashboard and restore xbox to factory default which I did and rerun the test. This time everything FINALLY passed. We were in business. I then decided to try connecting through my airport extreme router. I power cycled again starting with the airport then the modem then the xbox and ran the test and unbelievable as it sounds it all passed and my son is now sitting happily on the couch playing a game online with his xbox 360. This took away days of my life to get this simple thing done. I was given codes to change and change back on the computer, phone calls to everyone and the solution was so simple when you finally reach a knowledgeable person. Hope this will help save someone else the time I spent!
Oct 31, 2007 | Westell Wirespeed LiteLine 6100...
Actiontec GT701WG Router (actiongt701wg) Logo
231 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
