Question about HP PSC 750 All-In-One InkJet Printer
750 all in one printer
I have a paper jam and can't figure it out tried to remove most of it but couldn't get it all
Can you see any paper in the rollers? I can only think careful use of twesers AS you probably found out printers appear to be Snapped together ie no easy screws to undo! Have you tried the HP help line? Good luck!
Posted on Aug 25, 2008
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
I am unable to remove all of the paper from the jam. it is at the back of the machine.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP PSC 750 All-In-One InkJet Printer
Had paper jam, removed paper. Now it keeps telling me that it has jam paper still. There is no paper that is jam. Is there any type of reset button?
HP is a terrific printer. Try cancelling the print request in the computer, turning off the computer,then unplugging the printer, giving them a few minutes to re-set, then, then turn them on again. Also, look for a small, torn piece of paper within the printer, in case it is causing the issue. Best of luck.
Apr 11, 2010 | HP PSC 750 All-In-One InkJet Printer
Epson RX595 says "Error-paper jam" but no paper in printer!!!
I got my printer to work (finally! #$^%$%) by moving the ink carriage back and forth a bit gently and then I sprayed a small amount of WD40 on a lint free small cloth and wiped the silver bar inside with it. I slid the carriage slowly from one side to the left and it seemed to stick less. I thought my printer was broken so I figured it couldn't do any more harm and lo and behold it worked! My printer went back to the normal screen after turning it back on and I am finishing the print job that I never thought would happen. YAY!
Mar 20, 2010 | Epson RX595 Photo All-In-One Printer
Paper jams using nextech premium photo pape gloss finish
  1. Before you do anything else, turn the printer off and on by following these steps:
    1. Turn off the printer by pressing the Power button.
    2. If the optional HP Photosmart Internal Battery is not installed in the printer, unplug the printer power cord. Wait about 10 seconds, then plug the power cord back in.
    3. If the optional HP Photosmart Internal Battery is installed in the printer, unplug the printer power cord, if it is plugged in. Open the battery compartment cover and remove the battery. Wait about 10 seconds, then reinstall the battery. If desired, plug in the power cord.
    4. Turn on the printer. The printer checks for paper in the paper path and will automatically eject the jammed paper. Press OK to continue.
    If the error still occurs, go on to the next step.
  2. If the paper came part way through the front of the printer, gently pull the paper towards you to remove it.
  3. If the paper did not come part way through the front of the printer, try removing it from the back of the printer:
    1. Remove the paper from the In tray, then push in the catches to release the in tray. Figure 1: In tray catches c00256377.jpg
    2. Open the In tray to a horizontal position.
    3. Gently pull the jammed paper to remove it from the back of the printer.
    4. Before you lift the In tray to close it, make sure it is pushed all the way to the right on its hinges. Figure 2: Pushing the tray to the right before closing c00256378.jpg
    5. Lift the In tray up until it snaps back into paper-loading position.
  4. Open and close the pen door on the front of the printer to make sure it is securely latched. Figure 3: Opening and closing the pen door c00269435.gif
How to avoid paper jams
  • Make sure that the cartridge door on the front of the printer is securely closed.
  • If you experience paper jams while printing, try loading one sheet of photo paper at a time. Insert the paper as far as it will go into the In tray.
  • Do not add paper while the unit is printing.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Paper that has been printed previously may cause jams.
Aug 04, 2009 | HP Photosmart 375 InkJet Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
Paper jam
on the back side of the printer there is a assess door to remove the jammed paper in the printer.it has a channel like button on the backside.just rewind the channel to unlock the assess door and open the door towards you.and the door will come out into your hand.just remove the paper jam clearly look for any tiny pieces of paper in it.and then reverse the procedure to lock the door again.
Oct 05, 2008 | HP PSC 750 All-In-One InkJet Printer
Printer
When you clean the rollers, use alcohol. The clicking noise may be the plastic drive gears have a broken tooth.
Feb 04, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
