SYSTEM is neither turning on nor giving any beep sound.
I have changed the C MOS battery.but still no beep sound is coming after removal of ram and turning on the pc.
  • 99 Answers
Does it show any signs at all of powering up?
Posted on Jun 12, 2008
  • 96 Answers
Check the settings of your Bios or go back to the default settings.
My Laptop does not load and when i press any keys an alarm sound occur
if short beep sound coming from ur system then RAM faulty, so change the RAM . And long beep sound comes from ur system then ur Motherboard faulty , so change the motherboard.
Oct 07, 2012 | Toshiba Satellite Computers & Internet
I have dg31pr M/b,core 2 duo processor,i have 2x2gb ram 667,but long beep sound are coming from,and remove one memory system is working,and put another ram beep sound coming,how to solve this problem?
Sounds like bad or incompatible memory. I would replace the stick giving you issues, try to find a matching memory stick to the one that is working.
Hope this helps
Jan 25, 2012 | Intel DG31PR Motherboard
When powering the laptop, it has power for about 4 seconds and then turns off. The screen doesn't come on or doesn't even start the booting process. What would cause this to happen?
Are you using battery power or is it connected to your power outlet (AC = alternating current)?
If you're on battery make sure that the there is enough charge for the battery to turn on your computer, you can also try to remove the battery and plug it directly to AC, otherwise your laptop may have a bad hardware (mobo, RAM, Videocard, etc) does it give you any beeping sound when you turn it on?
(If you feel confident enough)
You can try to remove the RAM, Hard disk drive, wireless card on the back of your laptop then try turning the computer on and check if it will give you any beeping noise. Now put the parts you have removed back to the computer one by one while turning on the computer before putting the next one in. (Example: put the RAM in turn the computer on, turn it off again then put the Hard disk drive in and so goes the other parts)
If the above steps does not work. You can try calling Sony so they can check on the motherboard and the video card of your laptop.
Hope this helps!
Apr 12, 2011 | Toshiba Satellite X200-AA3 Notebook
No display
just remove the ram and athe cmos battery and stsrt if it give you the beep sound then it ram problem just clean the ram and fix it again.
Dec 31, 2009 | ASUS K8V-MX Motherboard
I HEARD A LONG BEEPING AND NOW COMPUTER WILL NOT COME ON
Check the memory if it is properly fix in to the motherboard or change it slot on the mother board and clear the cemos battery
Aug 23, 2009 | Intel DG31PR Motherboard
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
