Color problems, do not know original settings
  • noemaniago Jun 23, 2008
    first, one of the color disappeared, looks like the green color vanished and the pictures turned to be more red. It was like this for awhile. Then I'm getting double images on the picture and smaller until recently no more picture and the screen turned blue. Then I heard popping noise and smelled smoke. Immediately unplug the set, removed the sides, rear and front covers to investigate. Found that the middle tube circuit card assy to be burn't.
    Can you send me a manual, schematic diagrams and a troubleshooting guide, so that I can pinpoint the parts I need to replace and order, so I can restore back our tv set.
    TV Set Info: AKAI
    Type : 55W3
    Model : PT5598HD
    Serial # : 3800?CEWC00408X
    Made: Mexico
That happened to us as well but ours doesnt have any red at all any help would be appriciated.
thanks
Posted on Jul 20, 2008
What is the solution for e 001 problem
If its a Canon
#001
> Cause 1
Different sized originals were scanned without setting the Different Size Originals mode.
Remedy
Set the Different Size Originals mode, and then try scanning again.
Cause 2
Different sized originals were scanned in the 2-Sided Original without setting the Different Size Originals mode.
Remedy
May 11, 2015 | Office Equipment & Supplies
One of the kids have played with the picture settings of my akira tv and I don't know the original settings of the tv. Can you pleas e tell me about the original numbers
Set it to default picture state. Refer its user manual for details. In most cases, the default picture will have more color than normal. Reduce the color intensity, as you like to see.
Oct 19, 2013 | Televison & Video
I have a Hitachi Model 50V715 HDTV that I believe has a convergence problem, but I want to check to see that it isn't just an imbalance in colors that can be fixed with the remote. I understand that the...
i have a hitachi 46f500 rear projection hd t.v., i get a yellow and blue images i still can see other colours behind, i would like to know how to fix this problem.and if its a part i have to buy let me know thank you in advance.
my e-mail is stambene@shaw.ca
Sep 28, 2010 | Hitachi 50V715 50" Rear Projection...
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
Blue color is ober screen
It may be the fluid in the CRT or convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 30, 2009 | Philips 46PP9302 46" Rear Projection...
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Jul 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Colors are out of tune
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 09, 2007 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
Electro Med Services...
