Question about Haier HTF24R21 24" TV
Modo de servicio
Hola y saludos,busco la manera para entrar al modo de servicio pa, un T.V haier modelo :HTF21S34...muchas gracias por su tiempo y espero una resepuesta util por favor...adios(my name is EMILIO ANTONIOS i,m from venezuela-caracas,please i need the mode of servic for T.V HAIER mod.HTF21S34 please waiting for your answer....thank you
krohiti
  • 78 Answers
SOURCE: haier flat screen 25 inch
You might need to go through this manual before you scratch your head out...
http://www.haieramerica.com/en/support/modelsearch
Your modem no is HTF24R21 type that model no in the search field and you will download the Entire Adobe Acrobat eManual.
was i helpful dear?
Posted on Nov 24, 2008
SOURCE: remoe code for haier tv model tdc1314s
haier htn 13r12 13''tv have no vertical i change vertical ic it still remain the same .what could be the problem
Posted on Nov 19, 2008
Benimur
  • 6966 Answers
SOURCE: need code for "20" Haier tv model tn201auv for rca guide plus+gem
Hi again,
It would seem that you posted multiple times.
For the manual of an RCA CRK76TA1 remote control, pls click here. It is a pdf file and would require Adobe Acrobat reader.
Offhandamnot sure if an RCA remote would work with a Haier television. Youcouldof course still try: 140 191 0000 10748 0001 002 003 004 005 006085 086223 323 2000.
Just a start, do postback how thingsturned up or should you need additional information. Good luck andThank you for using FixYa.
Posted on Dec 04, 2008
villamore
  • 27 Answers
SOURCE: one for all code for haier air conditioner
it depends upon the model, when you buy the remote there's a list of the unit that you may used into it. and also indicates there the code, just follow the instruction
Posted on Jul 31, 2009
SOURCE: Need service manual or parts diagram for Haier HPRD12XH5 Air Cond
Here's its product manual
http://haier.afg-corp.com/1040ac7a68.pdf
Posted on Aug 11, 2010
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
Jul 30, 2013 | Televison & Video
Necesito programar un control a tv insignia?
Hola Maria, sera un placer asistirle con la inforamcion que necesita. Disculpe la tardanza en responderle. Quizas en este momento ya no necesite mi ayuda pero de todas manera se la proveere por si en un futuro la necesita. Para que su control funcione con tu TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Sigua este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV (Insignia). Una vez hagas esto te aparecesaran los codigos que posiblemente funcionan con tu TV. El procedimiento a programar su control es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 720#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor o subir el volumen, deberia funcionar. Si funciona asegurese de poner el control en modo de satellite de Nuevo. Esto lo hace oprimiendo el boton de SAT en la parte de arriba de su control una vez solamente. Espero esto le ayude al no ser asi por favor envieme un correo electronico directamente a kimberly.escobar@dish.com
Kimberly Escobar Social Media Representative DISH L.L.C
Jan 16, 2013 | DISH Network IR Remote Control
CONFIGURACION DE DIS POR CAMBIO DE DOMICILIO
Estimado Abel, gracias por tomar el tiempo de contactarnos. Lamento escuchar que este teniendo un problema con la configuracion del receptor. Usualmente cuando uno de nuestros clientes se muda de domicilio nosotros ofrecemos instalacion en el nuevo hogar, enviamos a un technico a que se ocupe de todo, de esta manera nuestros clientes no se tiene que preocupar de nada. Dependiendo del equipo y servicio que usted tenga la antenna debera ser instalada para cierta direccion. Que mensaje le aparece en la pantalla cuando prende el televisor? Me encantaria ayudarle con esto. Por favor contacteme a kimberly.escobar@dish.com con su numero de cuenta y con los detalles en sobre lo que le aparece en la pantalla. Espero escuchar de usted pronto para resolver esto. Gracias por su tiempo.
Mar 12, 2012 | DISH Network IR Remote Control
Hola tengo un control dish network y una television philips y no tengo el codigo
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Philips. Hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 566,770,741,628, y 521. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 566#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contacteme directamente al kimberly.escobar@dish.com. Gracias y espero esto le sirva de ayuda.
Feb 17, 2012 | DISH Network IR Remote Control
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Necesito saber cuanto es el tiempo de duracion de la bateria,en estado continuo de operacion
Hola y bienvenido a FixYa
Bueno por lo general cuando las laptops son nuevas la bateria tienden a durar hasta 4-5 horas dependiendo si estas viendo una pelicula o que recursos de la laptop estes usando, y para las netbooks cuando son nuevas tienden a durar en tiempo continuo un poco mas de 6 horas , entre 6 y 7, ojo repito estos tiempos es cuando los equipos son nuevos, recuerda que la bateria por su composicion siempre tienen un tiempo de vida y a medida que la vayas utilizando mas cargando y descargando ella se va consumiendo su tiempo de vida.
Un tip para alargar la vida de las baterias es cuando dejes cargando tu laptop y veas que ya encendio la laptop de que ya esta full carga, desconectala del cargador.
Otra cosa es si me proporcionas la marca y el modelo exacto de tu laptop y me dices cuanto tiempo tiene de uso o si es nueva te puedo decir con mucha mas precision el tiempo de duracion de la bateria de tu laptop.
Espero que esta informacion te sea util
Sinceramente,
aDynamite.
Feb 28, 2011 | Computers & Internet
La auja de la temperatura noo marca quisiera saber cual es el problema
lo mas probable es que el sensor de la temperatura este en malas condiciones posiblemente desconectado este sensor se encuentra cersa de la manguera de el radiador en el lado de el motor yeva un conector con dos cables primero deve de ser inspeccionado el conector por algun falso contacto aunque la manera correcta es usar un scaner es casi seguro que el sensor esta en mal estado para cambiarlo solo se desatornilla girandolo al contrario del reloj y se pone de igual manera solo cambia la direccion de del giro espero esto sea de alluda para su caso gracias por su tiempo.
Feb 23, 2011 | 1998 Ford Explorer
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Mar 15, 2009 | Sony XVM-R70 7 in. Car Monitor
Haier HTF24R21 24" TV Logo
291 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
