Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Lightning strike a recent lightning strike hit a tree by my house and has disabled my tv. when you plug it in the green power light stays on but the tv dont come on. I found the fuse next to where the plug comes into the tv and i tested it with a ohm meter and its ok. Is there anything i can do to fix it or is it a boat anchor
    Problem Solver:
  • 7 Answers
Hello bkindle.....not a boat anchor YET!!!! Had similar problem with WS-55513 and it turned out to be a faulty DM board. There are 4 capacitors on the board that may have blown. If yo can solder, it is a pretty easy repair. I purchased a PDF manual for mine online to get familiar with the model.
Otherwise, you can expect to pay between 275.00 for a repaired board OR between 350.00 and 450.00 for a replacement board from Sears or Mitsubishi.
Hope this helps. I know it is frustrating but be patient.
Good Luck - Richard (MetalDad)
email: PentiumDreams@aol.com
Posted on Jun 14, 2008
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
We had a thunderstorm with lightening in the area. The LG was plugged in at the time, but NOT turned on. after the storm, the tv will not turn on. the little green button turns from red to green...
As an electrician, when someone loses more than 1 item of electronics in a day, its almost
always traceable to a nearby lightning strike, accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
The converter box may be replaced by DirecTV, you'd have to contact their customer
service at http://www.directv.com/DTVAPP/content/customerservice
If desperate, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Aug 17, 2011 | LG Televison & Video
We had a tree struck by lightning last night. Now, our truck and sports car, parked 10 feet away, are both showing problems with charging system, (truck) and ABS, tracking system, and active handling...
Yes. Although the tires are suppose to insulate, there is enough humidity to allow the air to carry a charge. The ECM for example, can be interfered with by Radio frequencies. A lightning strike produces all kinds of freqencies beyond visible light.
You should document the tree strike and park your vehicles back into their spots if you do not already have photos of the tree damage showing the vehicles in the foreground or background.
This is comprehensive coverage with hidden damage discovered within a recent timeframe of the original event.
Aug 03, 2011 | Ford F-150 Cars & Trucks
My tv comes on and has "unusable signal" floating on it
What is your signal source, OTA or cable? Did lightning or another type of power surge recently hit? Make sure you have the TV on the desired input.
If OTA check your antenna direction and that you have the Channel Setup (from the menu) set to Antenna. Also check if you have the right antenna to get stations in your area. Antennaweb.org gives the most likely channels and directions. tvfool.com will give more detailed information and more stations. Both sites assume outdoor antennas but the direction information is always good. Look for new construction or big trees that might block the signal. Do you have multiple TVs sharing the same antenna? You might need an amplifier.
If cable, check the Channel setup. Check for someone recently damaging your cable installation (cutting the wires, trying to split the signal to get it for free) Splitting the signal to multiple TVs may also be an issue, get an amplifier of the correct type. Some cable systems may require a bidirectional amplifier.
If you recently had a power surge, see if the TV works with other inputs.
Tuners can be replaced if the TV is worth the labor costs for you.
I hope this helps.
( My household had three tvs and a digital to analog converter that lost their tuners after a nearby lightning strike. We chose to replace the TVs since two were over 15 years old and the third was also out of warranty.)
Apr 13, 2010 | RCA L46WD22 Television
Lightning strike
This model is famous for capacitors being bad in the low voltage regulators on the signal board. Also has been known for cold solder connections in the power supply to the convergence IC. I don't have my notes at home but I belive that model only uses one IC for convergence, STK393-570. You cant see it from the back because of it being hidden by its heat sink.
Jun 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Lightning strike
Lightning hits do some nasty damage to electronics.
Alot of times that type of repair is part of an insurance claim. The insurance company requires estimates and will repair them up to the cost of replacement.
If you arent dealing with an insurance claim on this I'd still recommend a professional estimate.
Lightning damage sometimes is confined to the power supply and once repaired could be fine bit in my experience most items that take a nasty hit are a write off.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 18, 2007 | TruTech PLV16320 Television
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
