Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Problem with Mitsubishi HD 1080
Ok, i have NO remote and the i think the t.v. has somehow locked itelf, none of the buttons worked so i just unplugged the whole t.v. and now it won't turn back on...can you help me?
Yes. When you moved it you likely broke a cold solder joint on one of the circuit boards. Since Mits RPTVs are renown for their bad convergence ICs that is where I would start.
The ICs get hot and the solder joints give way sometimes causing the ICs to fail. Mitsubishi's are famous for this problem.
If you are going to do it yourself, you will need a service manual.
If you are going to call in a repair tech, have him check the convergence board first and then the main power supply board.
Sorry it is not good news.
Posted on Sep 25, 2008
i got to college and put this tv in our room, but it will only go up to channel 11. i tried changing the setting from ant-A to ant-B, with still no luck. Is there a way you can search for other available channels or change a setting that will fix this?
Thanks
Posted on Sep 08, 2008
  • 126 Answers
Try to get number for tv call dealer get right remote
Posted on Jun 21, 2008
I locked the front button on me 50 inch tv its a mitsubishi 1080 hd series and dont have the remote i do i reset the thing
the only way to reset this thing is to bring new remote for this model & unlock with it. get the original remote from authorized service station.
Aug 19, 2011 | Mitsubishi VS-50111 50" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Locked key pad
The procedure to unlock the key pad is to hold down the MENU button for 15 seconds. If that doesn't do it you have a problem.
Dec 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
No controls
this should be easy to fix. The first thing is to check the buttons. Make sure that the buttons ar not pushed in and they work. What I meen is that when you push a button make sure it makes a cliking noise when you push it and releas it. If it dose not that is your problem. If they all work, Unplug the tv for 30 min. then plug it back in. It should work after that. If the remote dose not work after unplugging the set, you may have internal problems
Mar 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
