-   Yes.. I have the same problem of condensation with my Handy cam and it is not the first time but third time in the past 6 years..
Can some body guide us with the help of diagram.. which cover should be removed to avoid any problem. -   nitinsanap
Nov 03, 2008
-   where is the condesation sensor - how do I access it?-   pdxguy
Sep 29, 2008
-   Our condensation light is flashing, but the tape cannot be put into machine as the door will not stay closed. If the battery is on it powers up itself and just sits and rattles for a few seconds and then stops. What cover do you mean to take off and clean condensation sensor. How do you know which one you need to clean? Thanks-   Frankie-babe
I was going to purchase a Jazz Dv142 5MO Digital Camcorder, does anyone know if they are a good...
(More)
I was going to purchase a Jazz Dv142 5MO Digital Camcorder, does anyone know if they are a good camera?
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution...
(More)
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution or megapixel
when going to record the screen is white and then it will ask you to push the reset button after...
(More)
when going to record the screen is white and then it will ask you to push the reset button after this the screen goes black Regards Doug
When a phto is taken without flash, the picure is not clear. It has grains in it. And when I try to...
(More)
When a phto is taken without flash, the picure is not clear. It has grains in it. And when I try to make the picture big on the Pc, it pixelates. How can I solve this problem?
