Question about Vizio L32 32 in. LCD HDTV
Opening the back of a tv
I was wondering if you had any insight into opening a magnavox lcd tv (23mf231d). I wanted to get the black back cover off so I can take a look inside/
  • Vizio Master
  • 12,061 Answers
DON'T.. is all I can say unless ya got a real good reason ya really shouldn't do such... Just for a "Look"
However.... usually there are Philips Screws, 4 - 6 or so, around the outside of the Rear Casing Look for Big Holes usually with an arrow or such close by.. remove these and carefully pull back on the Casing and there ya should go..
Be careful there are LETHAL Voltages/Currents.
As an aside whenever one works on any TV equipment it MUST be powered via an ISOLATION Transformer AT ALL TIMES.. as sometimes the actual metal Chassis etc is at MAINS POTENTIAL.. as such is LETHAL Be CAREFUL.
Posted on Jul 28, 2008
  • 868 Answers
Why??
Posted on Jun 14, 2008
Magnavox 32MF301B/F7 32 in. LCD TV - my TV turns on by itself. What can I do about that?
Is it in a location that allows the sun to shine directly on it? Sometimes the light can trick the infrared sensor for the remote. Also, does the TV have any self timers enabled?
Feb 24, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
TV JUST SHUT OFF
Check power outlet and ensure there is power. If necessary, try the TV on some other power outlet. If it does not switch on, it is better to call in a qualified service technician, as back cover has to be opened.
Aug 16, 2012 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Black screen, only sound
common problem with LCD TV is a dead screen but there is a sound. so the problem is always coming from inverter board inside the lcd, inverter board controls the ccfl bulbs that illuminate the image in the screen. there are 4 or more bulbs inside your screen supplied by inverter board. you can see this inside at the back of the screen there are 4 boards inside, display driver board,power supply board ,inverter board and input board, this could be repaired or replace.but you need some tools for opening the case and test equipment. add comment if you want some help.. hope i help you.... thanks.....
Aug 31, 2011 | AOMNI Corporation Magnavox 20MF500T/17 20...
Power will not stay on , on my magnavox tv model 32mf337b/27 unplugged like user manual suggested but didnt work even after 30 hrs saw on magnavox.com a few people have had same proble with this model mine...
Magnavox has issues with puffed caps on the power supply. This sounds like its a 32 inch lcd tv. I tried searching for a service manual for this and can't find one. If it is an lcd you need to look at the capacitors on the power supply. If they are puffed up, you will need to replace them with equal or slightly larger valued capacitors. The capacitor values are mfd and voltage printed on the capacitors themselves. You will need a soldering iron to replace them. Lay the tv, if it is an lcd, on a flat surface cushioned by a blanket. Make sure the surface is large enough to support the tv frame, as you don't want to cause damage to the panel. remove the back of the tv. There are numerous screws, and once the back is off, check the power supply pcb for puffed caps. This is the board with the power cord attached. I know in magnavox tv there is a cage covering the power supply, so remove any connectors because you will have to flip the cage housing the power supply to get to the caps. If you feel confident, give it a try. Let me know how it goes
Apr 03, 2011 | Televison & Video
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Troubleshooting magnavox television model 20mt1331-17
I have a model 20tm1331-17 magnavox tv and when i go to turn it on it will turn itself back off. Any suggestions as to the problem?
Sep 27, 2009 | AOMNI Corporation Magnavox 20MF500T/17 20...
Magnavox 42MF531D black screen
Common issue I have come across when using any TV as a PC monitor. Best workaround i found is just dont change inputs or reboot the PC and the tv will pick it back up.
Sep 01, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox: 37MF231D/331D/321D
Calm down Calm down. The problem is quite simple. You need to change one maybe two capacitors. Upon removing back cover. Look to the left, after removing foil tape, remove screws and flipover the board. The first cap to go down may have abulge on top or black tar oozing out the top. It is a 25volt 2200mf cap gone bad. Replace it. Second, sometimes and just sometimes next to thatone is 35volt 1200mf cap goes bad......remember just sometimes. You may have to replace it as well.
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Vizio L32 32 in. LCD HDTV Logo
213 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
