Question about Cameras
I turn on my samsung s860 and it beeps twice, then the lens will not fully extend and it beeps twice again. It will not fully retract and has the same beeping. I have put in new batteries, it has not been dropped or exposed to liquid of any kind. Its kept out of extreme heat. It worked fine this afternoon and now having this problem.
  • Anonymous Dec 09, 2008
    when i press the power button it hesitates then beeps. The lens look stuck but im not sure.
    Novelist:
  • 97 Answers
I'm not sure what type of batteries you are currently using, but if you are using regular alkaline batteries, I would suggest trying some lithium ones. They are a little more expensive but they're a lot better in digital devices and they last a lot longer too. You can find them anywhere they sell batteries. They're the energizer e2 ones in the blue package.
Posted on Jun 12, 2008
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Samsung S860. Lens will not go all the way out without pulling it out manually and then when I turn camera off, it only retracts half way.
you have a damaged lens unit.
in warranty = 35.00
out of warranty = 165.00
continental photo,**************ask for vic
Jul 31, 2011 | Samsung S860 Digital Camera
The camera turns on but it is all blurry. And when I turn it off it beeps twice and the lense won't go all the way in.
Sounds like your lens assembly is damaged, it isn't able to twist the lens appropriately in order to fully close it or to focus in on the images you want. You will more than likely need to have the camera serviced. In most cases if it isn't under its warranty it will be a repair ranging close to $100, which is typically the cost of a new camera. Check your date of purchase as camera's come with at least a 1 year manufacturer's warranty, and hopefully you can get set straight.
Mar 13, 2011 | Samsung S860 Digital Camera
My Samsung S860 will no longer focus and will only take blurry photos. When you press the power button to off, when the lenses retracts, it beeps twice. Is this fixable?
Yes, the problem of your camera still repairable and I hope only adjustment of focus or cleaning of gear inside of the lens.
If you can open your camera and try to adjust the focus gear or clean the gear inside of lens.kindly check alos if the cable is not broken and connected properly.
goodluck and thank you my friend
Jul 17, 2010 | Samsung S860 Digital Camera
I have a samsung 860 digital camera ang my problem is the lens... the lens is still retracted even its turned off... before it happened the camera have a low battery.. and when i charged the battery for...
This may be similar to another solution posted. Try heavy duty batteries - I used ACDelco Super Alkaline, but any brand of "heavy duty" AA should work. Make sure battereis are not cold; low temp causes any battery to lose power. If fresh heavy duty batteries do not help, it may need professional service. (DO NOT try to force the lens back to retracted position - something WILL break.)
Dec 18, 2009 | Samsung S860 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
Samsung s860 camera lens will not close and is out of focus.
I hate to say it but your camera needs to be serviced. Might not be worth the repair. Try to take it to a local repair center that would offer you a free estimate....
May 30, 2009 | Samsung S860 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Cameras Logo
267 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
