Question about Gateway 7330GZ Notebook
Replacing the screen on the 7330gz
I already have a replacement screen and can't really afford to take it down to have it professionally done. How can I do it myself?
    Scholar:
  • 50 Answers
CHPMarine -
Replacing an LCD screen in a laptop is no simple process; It generally involves dismantling a LOT of the computer just to access the connectors and brackets for the screen. I recommend having it done by a tech if you can - take a look at www.craigslist.org to find a tech in your area in need of work; many people will advertise tech support under the Services Offered position for a very low cost.
Otherwise, there are several screws you need to remove. On the bottom of the computer are generally between two and six screws that hold the power/hinge bezel in place, as well as the keyboard. Remove these screws and CAREFULLY pull up the bezel. The keyboard may also have screws under that bezel, remove those before lifting the keyboard (usually doesn't have to be completely disconnected, just shifted aside, but don't stress the ribbon cable that connects the keyboard to the motherboard too much).
With the bezel and keyboard out of the way, you should see a cable that connects the motherboard to the LCD through one of the LCD hinges. Disconnect that cable.
The plastics covering the LCD should have a handful of rubber or plastic 'plugs', between four and ten of 'em, with small screws located underneath each. Remove these screws, then very gently use a small flathead screwdriver to pry the LCD plastics apart at the seams along the side.
Once the front plastics are removed from the LCD, disconnect the long, slim PCB that rests beneath the actual screen. Remove the screws that hold the screen to the mounting brackets along its sides, and the LCD should be loose. Carefully lift it from the rear plastic cover, and you'll see a ribbon cable connected to the display. Release the clips that hold the ribbon cable in place on the screen, and you're ready to put in the new LCD!
I know its long and circuitous, but repeat the steps above in reverse to install the new screen.
Hope this helps!
-thinstatic
Posted on Jun 12, 2008
Why is gateway laptop screen shaking
The dreaded loose video chip. pay $100 and have a professional fix it for you. There are several listed on-line that take them apart and will heat the solder joints back up to fix it.
Jun 12, 2014 | Gateway 7330GZ Notebook
I have a Baby Lock Esante ESI and the light that shows the Letters & Numbers for the embroidery function has burned out. I would prefer to have the repair done by a professional but am unable to locate...
Have you checked the dealer locator at the Babylock website?
Another option would be a Brother dealer as the machines are from the same "family".
Apr 25, 2010 | Baby Lock Esante
How to change timing belt
Changing a timing belt is not a DIY job for the inexperienced, especially on an interference engine which the Prelude has. Do it incorrectly, and serious engine damage will occur when the engine is started. Take it to a professional for this repair. Also replace the water pump and service the cooling system at the same time. This will save you money on labor down the road, as most of the labor coast of replacing the pump will have already been done when replacing the cam belt. If the pump has already been replaced, then disregard this.
Oct 15, 2009 | 1998 Honda Prelude
Need to replace screen on my Sony Ericsson Z310i
You should definitely have it done professionally. Replacing a screen nowadays is very hard. Since electronics are factory made now, instead of hand made, it is really hard to duplicate the process made. I've opened up several things, thinking that I could just pop out the screen and put in a new one (PSP, Nintendo DS Lite, a few cell phones), only to see how many things you have to line up and just abandon the process. Call your service provider and see if they can help you out. If your phone is still under warranty, you can get it done for free. If not, you might have to pay some money.
~Aeoryth
Jul 06, 2009 | Motorola Mobility RAZR V3i Cellular Phone
W580i most of screen taken up by vertical and horizontal lines help. already reinstalled the sw from the sony media mgr
More than likely you will need to replace the display screen. Those lines are a symptom of the LCD screen going bad. If you are still under warranty, see if you can get it replaced
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
May 31, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
I need to replace the backlight on my laptop
Majority of the time it's NOT the backlight, it's the inverter. Who told you that it was the backlight specifically?
Virtually every lcd is the same procedure. Just remove the screws around the lcd, some are hidden under the rubbers, and CAREFULLY pry the plastic surrounding the lcd. It's basically common sense. Just take it apart....CAREFULLY.
That's about it, really.
May 11, 2009 | Gateway 7330GZ Notebook
Laptop screen will not come on
Incompatible screen - replace the screen.
Mar 12, 2009 | Gateway 7330GZ Notebook
Numbers and backspace on Gateway 7330GZ not working
You might check and clean the keyboard connection to the motherboard. However, usually this indicates keyboard failure. It's most likely that you're have to replace the keyboard.
Aug 21, 2008 | Gateway 7330GZ Notebook
Screen problems
Try the power save options.
Nov 13, 2007 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
