Question about Frigidaire Affinity ATF7000E Front Load Washer
Help!!!!!!!!! Just plugged in my new front load washer, the washer is not on and water is seeping into the drum!!!!!!!!!!!!!!!!!
  • 1,294 Answers
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares: (which is good)
Pl rate if helped.............
Posted on Jun 12, 2008
My 6 year old Frigidaire front load washer makes a lound banging noise during final spin. I have read a bunch of stuff on the net about it being really expensive to fix. I never noticed that the drum...
A typical failure with your machine is that the rear tub seal may seep water into the bearings. Once moisture enters the bearings, they will quickly fail and cause the type of symptoms you mention. I would suggest purchasing a new machine as the repair cost can't be justified. Whirlpool / Maytag machines are very good and, at least relating to top loading, they are all made in USA. If you want a front loading machine made in USA, I would highly recommend the WFW94HEX model- Consumer Reports #1 rated.
Good luck.
Mar 27, 2011 | Frigidaire ATF6000ES Front Load Washer
The machine works OK but when finished, with the two water valves left on, the drum fills with the machine turned off
Replace your water inlet valves in washer they are seeping water.... If I helped please vote need more help please ask.....Good luck
Feb 07, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Water appears in drum after time.
Sounds like you have a seeping water valve. Turn water off at shut off valve and see if that corrects problem, is so replace water valve
Sep 03, 2010 | Kenmore Elite 45986 Front Load Washer
Water seeps into Whirpool Duet washer
If your washer is leaking water when it is not in use, the following link explains how to troubleshoot to isolate the cause:
The problem is either attributed to a defective pressure switch or a water inlet valve that is leaking by. The link I provided will explain how to determine which one.
If you still require assistance, please let me know.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
Kenmore front load washer when spinning sounds like a jet engine. It actually hurts you ears and you cannot shout loud enough to be heard. Spins out fine but is so loud.
It's probally the bearings are going bad. If you try to turn the drum by hand and it does not turn smoothly or has a rumbling sound, it means the bearings are bad. I had the same thing happen to my washer. Water seeped past the seal and the water started to rust out the inner bearing. You need to pull the washer apart to get to the bearings if you are handy. If not, the parts and labor are more than the price of a new machine.
Nov 19, 2009 | Kenmore 44102 Front Load Washer
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Water that seeps into washer after cycle is done
Hi, If you are getting water in the tub when the washer is off, you will need a new inlet mixer valve. You can test this by tirning the water off at the wall and see if any water seeps in. If you would get me a model #, Icould look this up for you.
Please let me know if I can assist you further.
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
106 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
