Question about Whirlpool Dryers
I have a whirlpool gas dryer model number LGR5636JQ1. The belt burner up, when I went to replace it I noticed the thick plastic piece on the motor shaft had melted. Is this piece necessary? If so how do you remove and replace it without damaging the motor? Does the belt ride on that or the grooved fitting on the end of the shaft?
  • 77 Answers
I assume you mean the cone shaped plastic on the motor shaft. this is not necessary, it is there to keep a worn belt from riding onto the shaft. if the belt and idler(should be replace with belt) are good it shouldn't cause a problem.
J
Posted on Jun 12, 2008
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
Whirlpool Gas Dryer Model # LGR7646JQ0. Bought it used, warranty useless since the shop I got it from went out of business. Everything works fine. The drum turns, the timer works but the thing doesn't heat...
Hi and welcome to FixYa. I am Kelly.
Your power for the burner assy goes on a series circuit from the timer to the high-limit thermostat to the operating thermostat to the thermal fuse to the gas burner assy, thru the motor centrifugal switch to the door switch. EACH of these must be functioning for the burner to light.
This manual will help with some of the how to do it as far as component access, removal and replacement of parts.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
Also this link has loads of information on what to check.
http://fixitnow.com/wp/2006/09/19/how-to-check-the-burner-components-in-a-gas-dryer/
The 3 most common failures are
Igniter:
Gas Valve
High Limit Thermostat
Compnents : http://fixitnow.com/appliantology/gasdryer.htm
Note the LINKS!
Here is a 9 min video that pretty much covers everything you need to check: http://www.howcast.com/videos/371390-How-To-Troubleshoot-a-Gas-Dryer-That-Wont-Heat
Thanks fo choosing FixYa.
Kelly
The
Aug 20, 2010 | Whirlpool LGB6300 Gas Dryer
Belt for Kenmore 92284800 Washer?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://beta.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=11092284800&productCategoryId=0153200&brandId=0582&searchedModel=92284800&blt=06
and you'll see a list of major sub-components with diagrams and parts.
NOTE: THIS MODEL NUMBER DOES NOT USE A BELT.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Jul 31, 2010 | Kenmore 3.2 cu. ft. Top Load Washer
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Need help with my whirlpool dyer a white wheel came off dont know were it goes
The small white plastic white wheel goes to the idler pulley. It is located to the left of the burner assembly on the bottom cabinet behind the blower fan assembly. This is what keeps the belt tightly around the drum. There is an excellent illustration of this at pcappliancerepair.com. Just type in your model number and look for item 13 under the "Cabinet Parts" heading. The idler pulley attaches to the idler bracket (item 39).
There should be a small triangle shaped retaining clip that keeps the pulley in place on the shaft. It is known as a "tri-clip". If the clip has broken off, you can purchase replacements at pcappliancerepair.com for about $3. The part number is 690997. There is also a thrust washer on the idler shaft. The part number 233520. Make sure it is still in place.
If the pulley needs replaced, the part number is 279640 and it comes with the thrust washer and tri-clip retainers for about $14.
To access, remove the toe panel directly below the door and remove the air blower assembly cover. Make sure you UNPLUG the dryer while servicing the cabinet interior. Dangerous voltage is still present while the unit is turned off. You should be able to reach behind the drive motor and find the spring activated idler bracket. The wheel mounts on the back side of it with the thrust washer installed first, and the tri-clip inserted last. Refer to the parts drawing for details.
NOTE: Without the tension on the belt, the idler bracket will trip a small switch that prevents the drive motor from running. This is known as a "broken belt switch" that keeps a broken belt from wrapping around the motor shaft and burning. So, if your dryer is running, this is why. You should be able to hear the switch toggle as you move the idler bracket up and down.
For details on how to reinstall your dryer belt, go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Locate the Whirlpool dryer belt link and refer to diagram K.
If you have questions, please let me know. I hope you find this information helpful.
Oct 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Belt broke and there is a small plastic part melted lying in bottom of dryer housing that looks like maybe some kind of a guide for the belt+a shoe type device lying in the bottom, looks like the belt goes...
sounds like the plastic take-up pulley on the motor which is spring loaded to keep the drum belt tight. You will have to replace the tensioner which should, depending on the model, include a new plastic pulley.
Oct 16, 2009 | Whirlpool LGR3624JQ Gas Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
Whirlpool gas Dryer LGR5636JQ1
theres a thermal fuse located on back panel usually white maybe 2 inches tall 1/2 wide 2 blue wires leading to it. ck for continuity, if none replace that(most common problem)... if good you can go back to the ignitor and unplug the white connector it plugs into. place your meter leads into the connector and turn on dryer, you should get 110v. if you do you have a bad ignitor, if not a thermo's gone bad (check the thermal fuse first though.
Mar 12, 2008 | Whirlpool LGR5636L Gas Dryer
Dryers Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
