Question about Logitech 967437-0403 Keyboard
Logitech keyboard default settings
How do you set the F Lock key so that it defaults to "on" position from boot up?
  • HPLab Jun 12, 2008
  • 903 Answers
Is there a key on the keyboard that says F mode? if there is press this to set it to F mode and then it will stay that way until you press it again
Posted on Oct 25, 2008
How to start in lower case letters when the Zagg keyboard defaults to a capital letter
Ruth Okimura (ZAGG keyboard defaults to Capitals)
(1) Press caps lock so LED goes off, and/or
(2) Depending on what OS you are using, open your System Defaults settings file, navigate to the {Start-Up} or {Boot} section.
Otherwise do a text-search for "Caps".
If the option exists on your OS, then:
Change the default boot-up setting to "Caps lock off".
Hope this helps. Clive.
edit: I'm referring to a PC keyboard here.
If ZAGG is some other device like tablet or phone, IDK. :)
Oct 06, 2017 | The Computers & Internet
Logitech Wave K350 won't boot with num lock on
Have you changed or updated anything else on your system? Added any other Bluetooth devices? I have the same KB, always boots with Num lock on. It worked with both Vista 64 and now Win 7. Maybe the driver and the specific USB port combination is not working. Try plugging the BT antenna into another USB port.
Mar 04, 2014 | Logitech Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
What is does the blue light with the 9 in a lock above the keyboard mean. and how do i turn it off. dell latitude e5510
9 in a lock light:
Turns on when the numeric keypad is enabled. Turn NumLk off by toggling the key.
You can change it in System Setup. Under Post Behavior heading.
Press to enter System Setup and make changes to user-definable settings. If you have trouble entering System Setup using this key, press when the keyboard lights first flash.
Use the checkbox to enable / disable the Num Lock LED when the system boots.
The factory default setting is Enabled.
May 21, 2011 | Dell Latitude E5510 Notebook PC
I have a Logitech cordless ex110 keyboard that I would like to find an online manual for....I have no idea what the 'F' keys do and every once in a while I hit something (?) that converts my /,...
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
The manual and other documentation for the Logitech ex110 is available here: http://www.logitech.com/en-us/433/154?selectedcrid=433&selectedcid=154&WT.z_sp=Product&osid=&bit= .
I hope this helps.
May 20, 2011 | Logitech Computers & Internet
How do I disable "Stickykeys"?
Sticky keys are enabled and disabled by pressing shift 5 times by default. If the default settings have not been changed, this should work for you. Hope this helped.
Dec 10, 2010 | Logitech Wireless Access Duo Optical...
BIOS Lock preventing reload on Tiny PC
For that you need to RESET your bios settings to factory defaults.
Open cpu cabinet cover and pull cmos cell from motherboard for 10 minutes then all settings goes to defaults.
You can also reset settings with jumper it is near cmos cell it has 3 pins 1-2-3 put jumper in 2-3 position then power up the computer then all settings defaults.
Then if you want to boot your computer with disk then when you power up the computer press F1 or F2 or del key to enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boot with your disk.Then follow the procedure on screen then you can reinstall your windows or recover old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
Wr6ng Entr5es fr60 2eyb6ard
it looks to me like you have your number lock on.
Aug 27, 2009 | Gateway 7001433 Keyboard
Logitech Wireless keyboard Lx710 some keys type the wrong letter.
Just go to yout logitech Setpoint Software and click on my keyboard. Then click on restore defaults settings then apply and ok.
Jul 27, 2009 | Logitech Computers & Internet
My programmable keys are no longer programmed.
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then click on the DEFAULT. This should reset all the keys to original setting.
Hope this will help some. Bud
Oct 02, 2008 | Logitech Cordless Desktop S 510
Logitech 967437-0403 Keyboard Logo
165 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
