I losted the remote so i bought a 4 in 1 universal remote it worked perfect until i turned it off then it would not come back on again. it has a timer and power button in one i dont know if that would have anything to do with it or not.what do you think is wrong with it
.i hope you can help me thank you
TRY UNPLUGGING THE T.V. FOR TEN MINUTES. THE TRY THE BUTTON ON THE FRONT OF THE SET. YOU SHOULD BE ABLE TO GET AN ORIGINAL REMOTE FOR AROUND $40 . DON.
Here are some codes you can try for Samsung brand TVs: 008, 011, 018, 021, 024, 025, 033, 037, 039, 040, 049, 050, 051, 091, 113, 123, 375, 378
To program the remote: 1. First turn on the television. 2. On the remote, hold down SET until the indicator light turns on. 3. Type in one of the three codes above (I would just try them in order). 4. If the code is accepted, the light will turn off. Press the power button on the remote; if the TV turns off, then the code is correct.
If the TV stays on, repeat steps 2 through 4 until you find a code that works.
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
With nearly all brands of universal remote control, there is usually more than one code for Philips. Keep going through the codes until you find one that works correctly.
So if you know that the 1st code doesn't work, then don't save it, and move to the next.
You may find that several codes will actually put the TV into standby, but other functions will be different.
I had this problem on a symphonic 27 inch TV I just bought from a friend
who no longer had a remote. The thing with the menu and buttons on the
front of the TV doesn't actually change the TV to true game mode. I
don't know what it acutally does, but it isn't really in game mode.
When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone
told me about) for 8 bucks at walmart and I was then able to switch to
game mode with the Input select on the remote. The remote I bought that
actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629 Make
sure you look at it before you buy it and make sure it has a button
that specifically says "input" on it. I know that some of the universal
remotes don't have an input select button or one that doesn't work. As
long as you get a Philips-Magnavox that has that button, you should be
ok. Much better solution that paying 30 bucks for a new remote
specifically for the TV. Hope this helps.
Hi the codes for hitachi are 0074,0082,0081,0511,0201,0616,0234,0236,0255,0232,0554,0110,0537,0075,0594,0147,0216,0143,0550,0518 turn on tv, 1.press tv button on the remote 2. press setup button until it flashes twice enter code then turn off by power button (keep repeating 1-3 until tv goes off) hope this helps.
try code 238, if it does not work you will need to try the code search.
1) turn on tv 2) press and hold "code search" until indicator light comes on 3) release code search 4) press and release "tv", indicator light should blink once 5) aim remote at tv and press the power button until the tv turns off (you may have to press it 200 or so times) 6) once the tv turn off, press enter on the remote
