Question about Propellerhead ReCycle 2.1 (7350002920091)
Recycle cannot run because of an unexpected error
When I try to open recycle appears this message: Recycle cannot run because of an unexpected error.
  • 4 more comments
  • elcarnicero Jun 12, 2008
    Thanksssssss!!!!!!!!!!!!!!!!!!!!!!
  • Ionut Dej Jul 04, 2008
    the same problem... unexpected error... odd thing is... it worked when I installed it fresh... 3 4 H before this erros... it`s odd... is it a Virus??? Must I install again my WINDOWS??? (using XP version)... installed just Yesterday... because of recycle... the same error... THANK YOU!
  • Anonymous Aug 20, 2008
    i have the same problem my recycle does not open up it says unexpected error
  • Anonymous Oct 02, 2008
    same problem i download the patch from propellerhead that too didnt work i am running xp pro sp3
  • haubose Oct 15, 2008
    i reinstalled recylcle a lot of times nothin changes.
    i got no 6t4 processor so i shouldnt load the patch riaght ?
  • sha104 Dec 07, 2008
    there are no patches available for 2.1 to run with sp3?? it worked well until i loaded sp3! WTF!!
Hey !
http://www.propellerheads.se/support_area/index.cfm?fuseaction=get_article&article=winx64recyclepatch
this worked well even if i am on an old sempron 2600 ... but , hey , give it a try , it worked for me ... hope this helps for real . no trojan virus , just a naughty DLL that didn't wanted to do it right ...
Posted on Sep 08, 2008
Hey !
And that sign up **** you really should stop that too so you can sell the info for 5ct you people make the internet bad assohole why don't put a gun to your head and end it all yo u are no use
Posted on Jul 05, 2008
Why don't you put something helpfull man you just wasting with that **** that you post you are a ******* you are
    Genius:
  • 1,011 Answers
Dear Sir,
This is the trojan virus. call a computer expert immediately and get the windows reloaded, before your pc crashes completely.
Thanks
Good luck
“Don’t Forget to rate the Solution”
Posted on Jun 12, 2008
ReCycle... with virus?
Instalad este parche los que tengais el SP3 instalado y procesador AMD y todo volverá a la normalidad.
Saludos
Jul 04, 2008 | Propellerhead ReCycle 2.1 (7350002920091)
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Windows CE device
Sep 14, 2005 | NEC MobilePro 880
Windows CE device
Sep 14, 2005 | NEC MobilePro 750
Windows CE device
Sep 14, 2005 | NEC MobilePro 250e
Propellerhead ReCycle 2.1 (7350002920091) Logo
17,148 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
