Home Theatre - No Video thru Receiver
I am trying to connect my home theater system to my set top box and TV. I cannot get video through the receiver to the monitor. There is no apparent HDMI input on the receiver from the set top box. Help!
  • Anonymous Nov 01, 2008
    No video out tof the svideo port
  • 32 Answers
Posted on Jun 12, 2008
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
No audio when watching HDTV and the home theatre receiver is set to cab/sat. HDMI cable is run from the receiver to the TV. Cable is run from the cable box to the receiver. Tried using "y" audio...
If your TV has HDMI in and digital optical out, run your HDMI cable via HDMI out on box to, HDMI in on TV then, run digital optical ouyt from TV to digital optical in on reciever. Your reciever has video pass through but, not the best option. Video components should run to TV then out to reciever. If you do not have digital optical out on TV, you may be able to use RCA.
Jun 24, 2011 | Insignia Audio Players & Recorders
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
Jun 27, 2009 | Audio Players & Recorders
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ... - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ... - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ... - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
How do i connect my tv and my hd cable box to the home theatre system so that the audio is heard thru the theatre system?
The best way to do this is to run all hdmi cables from the source to the receiver (i.e. from the cable box to the receiver). Then run a single hdmi cable from the "out to tv" or "video/audio" out jack on the receiver to the television. Turn the tv on and select the input you put the hdmi cable in, then on the receiver select whatever you want to watch, i.e. cable.
Dec 24, 2008 | Samsung HTZ-510 Theater System
they do make a adapter that converts composite video to s-video. Another way is to use a audio video receiver that converts composite video to hdmi. The model # is rx-v663 yamaha a/v receiver sold at bestbuy. The adapter which would be a lot cheaper is also on you can type in composite video to s video converter in search box on or google it.
Nov 04, 2008 | Samsung HT-X50 System
130 people viewed this question
