Question about Samsung UpStage SPH-m620 Cellular Phone
Charge Hi i bought this phone but i cant get it to charge i belive there is a loose connection on the cell adapter,can i charge the phone on the computer with the usb>?Thanks
    Genius:
  • 2,035 Answers
Yes}}}}}}} you can charge the phone from the usb port of the computer ...........
Posted on Jun 12, 2008
Iphone won't charge from ac adapter
contacts on ac insertion tip slightly damaged check by having friend or simular product attempt to charge theres ? yes it works on others?thenits your female reciever entry on phone is damaged due to tip end on charger being inseted when not aligned perfectly lots of phones do it if that is the case check policy on damage w/out posting your idenity generic review ,your most likely not covered so 2 choices get old phone same exact sameis required and charge back-up battery to op phone but smart phones freak on O.S. BEING YANKED OFF NOT GOOD 2ND IS LOOSE IT OR TURN EYE WHILE BAR FLY POCKETS REPORT GONE CANT SEE WHO GET REPACEMENT WHEN IT DOES FAIL OR GET SCREWED BY PHONE CO. LIKE US BUY 2ND IPHONE 1 WEEK AFTER 1ST ONE CARRY 2ND LINE AND WAIT 6 MO. FOR CYCLE TO DROP NON USED AIR WE PAID 129 MONTH ON BOTTOM DEAL WENT TO 200 +EA. MONTH YOUR CHOICE CRAIGSLIST EBAY AUCTIONS PAWN ARE MOE HONOABLE THEN SENARIO I AIRED MY PAIN I WOULD NEVER LET THE CO. HAVE MY MORALS OVER PHONE ISSUES OR ANY MATERIAL GOODS GOOD LUCK I WISH YOU WELL
May 02, 2012 | Apple iPhone 4 Black Smartphone
How do I charge the Handset? Where do I connect the base unit?
Hi julie Since you dint mention the model, you search for a pin that could be connected with the adapter. if you cant,just search for the USB port and plug it to your CPU. It will get charged!
Jun 27, 2011 | Cell Phones
My cell phone will not charge,,What can I do?
Ifthe phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.Check power adapter's DCplug that connects into the cell phone power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Apr 14, 2011 | AT&T Cell Phones
Battery is not charging fully even after i changed my battery it charges only up to 30% when i switch it off and on once again it becomes to just 4% .I cant send messages from the mobile W705 ,I have...
Ifthe recharable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 14, 2011 | Sony Ericsson W705A Cell Phone
THINKING IT WAS THE BATTERY I BOUGHT NEW BATTERY . WILL NOT CHARGE SO I PUT BACK OLD BATTERY AND STILL WILL NOT CHARGE. USUALLY IT WILL BEEP WHEN I PUT BACK IN CRADLE. BASE LIGHTS ARE ON /CHARGE INDICATOR...
Hello
This is either a problem with your charger or the charging port of your phone
Try charging your phone with another charger that works with you phone to see if it works,if it doesnt then you need to change your phone battery charger
Also you should wedge your battery at the bottom with a folded piece of paper because the battery might have become loose and doesnt fit in properly into its compartment so by doing that you will be providing better contact between battery and battery terminal.
If the above still doesn't make the battery charge then the problem is from the charging port of your phone.
The charging port is where you connect your charger into,it is probably damaged and needs to be looked into and replaced.
Oct 05, 2010 | Cell Phones
NOKIA 5300 low battery . . if i will charge in
hi...
I belive your usage of mobile is more.the battery charge wil depend on the usage of the mobile. If you use the mobile too much then the charge wil not last more.so there is no problem with the mobile or the battery
thanx
Jul 17, 2010 | Nokia 5300 Grey Cellular Phone
Cant charge
Check the following to fix your problem
  • Loose battery connection.
  • Bad battery.
  • Bad charger.
  • Bad phone.
  • Bad connection somewhere.
Best solution: Remove your battery, clean the contacts and reinstall. If the battery is bad, replace it. If the charger is bad, replace it.
If these things don't solve your problem you are left with replacing the phone.
Thank you !
May 19, 2010 | Nokia 6300 Cellular Phone
IPhone Smartphone: cant charge iphone in ibiza battery went flat...
Possible solutions
1. buy an adapter for your charger
2. plug it into a computer
3. provide more details than you have so far...
can't charge iphone is a vague way to explain your predicament...
can't charge or won't charge?
can't get an adapter?
don't have access to a computer?
Half solution, half clarification request...
May 16, 2010 | Apple iPhone Smartphone
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Samsung UpStage SPH-m620 Cellular Phone Logo
224 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
