Question about GE GSS25SGMBS Side by Side Refrigerator
Refrigerator not cooling
I have a Samsung refrigerator (side by side freezer and fridge). Eventhough the fridge side says 34 degrees, it isn't cooling. Freezer side is fine. What can I do? I have a GSS22JEMDBB made by GE my freezer coils keep freezing up into a chunk of ice, how do I keep it from doing that?
  • suebhoney1 Jun 29, 2008
    i have a ge side by side. the freezer side is working, bu the fridge side is just cool. a couple days before this, there was loud fan noise(of course it
    the noise stopped when i opened the door).
  • Anonymous Mar 22, 2014
    FREEZER IS COOLING, THE FRIDGE IS NOT.
    Genius:
  • 1,142 Answers
See if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
How do I get at and clean the condenser coil?
Posted on Jul 20, 2011
The cooler side of fridge does not work properly. Why?
Brand name and model number would help. It should be inside the refrigerator section usually on the upper right wall.
Link to youtube videos about this problem is below. One or more of them should help with your problem.
Go to http://searspartsdirect.com/ and enter your model number. If your model is sold by sears you can see diagrams, parts lists, manuals and get help and order parts.
side by side refrigerator not cooling YouTube
Sep 12, 2014 | Refrigerators
Fridge is freezing....
The way you've stated your problem is confusing? The temperature is the freezer should be 5 degrees F or below, preferably at 0 degrees F. The refrigerator side should be anywhere from 34 - 38 degrees F, What exactly is the problem your having, fresh food not cooling but freezer works ok?
May 07, 2012 | Westinghouse Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Open the panel in the freezer, and take a hair dryer to the frozen coil.
May 13, 2008 | Refrigerators
GE GSS25SGMBS Side by Side Refrigerator Logo
1,552 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
