Question about Gateway MT3705 Notebook
Can i upgrade my MT3705 to 4GB RAM?
According to my knowledge, this laptop can be upgraded to 2GB RAM with two 1GB slots. However, today i saw slots of 2GB and i was wondering what will happen if i install 2 slots of 2GB RAM. Will it work?
Thanks
  • Anonymous Mar 19, 2014
    How to upgrade from 1GB to 2GB.
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Posted on Nov 18, 2008
    Scholar:
  • 115 Answers
No it will not work the manufacture of the laptop is made by in that period is 2 GB is most high. That will be the most of the computer and laptops are sold by upgrading the components.
but most of the computers and laptops are not more upgradeable because the new models are introduced day by day they want lanuch the new computers and laptops so you cant upgrade to 4GB . maximum is 2 GB in your laptop.
bye
Posted on Jun 12, 2008
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
Can the 1 G of Ram be increased to 2 G of ram on a Compacq V3020
The specs for your laptop says that the maximum allowable RAM that it can hold is up to 2gb so yes you can upgrade it.
2 pieces of 1gb RAM (1gb per slot) or a single stick of 2gb on 1 slot.
Good Day.
Jun 29, 2011 | Compaq Presario V3020US (4400 mAh )
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Extensa 4620 memory upgrade
According to the manual up to 4gb on two .soDIMM for model ex4220 only.SO yes. I would  take them back and get one 2Gb strip. Download and read the manual first, in case I missed somethng.
Your User Manual: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/c434e20d60a3befe482573560024cc6e?OpenDocument
Jan 19, 2009 | Acer Extensa 4620 Notebook
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Gateway MT3705 Notebook Logo
837 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
