Question about ASUS P4P800-MX Motherboard
Power supply my power supply wrecked, so i bought a new one but nothing happens, but green light on board comes on. nothing else happens.i have pulled everything of the board but the fans and tried to power up and still nothing. all caps look good and no smells.please help!!!!!!
  • 84 Answers
I think your problem is not with the power supply, its the hdd or memory thats causing the problem. try to check the cables, and re insert the memory then start up your pc again.
allen
Posted on Jun 12, 2008
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
My tv wont turn on when i press the power button on the tv ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 03, 2014 | Philips Televison & Video
Intel D946GZIS machine will not start after being reassembled. The green light on the Motherboard is on but after hitting the power button nothing happens
It is more than likely the power supply that is faulty. Newer PSU's have a 5volt supply missing, this means that some older boards will not run with the new PSU's. Try and find an exact match for your older supply but with a better power rating, if that is what is required.
Jun 24, 2012 | Intel D946GZIS Motherboard
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
Lg 47lc7df tv blinks green light, no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 27, 2017 | LG 47LC7DF 47 in. LCD HDTV
I have a sanyo vizon 50" tv that wont turn on. the green light comes on and the relays click but nothing happens and eventually the light goes off. any advice? thanks
Power supply board have problems,not giving the tv,the right voltage anymore,that why the LED power light indication go off.The power supply board,that the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 13, 2010 | Sanyo Televison & Video
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
Wont load up
If everything is working properly, then yes, those lights are normal. Many motherboards have LEDs on them to show standby power. You probably didn't notice them until you worked on the thing.
Feb 25, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Wont power up
If you are getting absolutely nothing, and it seems you have checked all the obvious, then I guess its just the board given up
Dec 15, 2008 | Computers & Internet
ASUS P4P800-MX Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
