R52WH76 My TV power light keeps flashing on and off three times and then stays off. What is the problem. Also when I was moving from one place to another my screen broke the clear one and the black one behind it. When my tv does turn on you can see the picture but the screen is cracked. Where can I get replacement parts.
  • Servando Martinez
    Servando Martinez Jun 12, 2008
    The info you asked for is ITC222 and the model number is D52W20 and the serial number is E265C30I6
  • 8,617 Answers
Thats usually a sign of a bad flyback. I am not famillar with that model number, if you can post the Chassis number off the rear tag I should be able to help you out.
Posted on Jun 12, 2008
  • Sonny Berry
    Sonny Berry Jun 12, 2008
    Ok, thats a set I am real famillar with. You need a flyback, they are very easy to replace nothing to it actually. You can get a new replacement flyback at the following link and they will help you install with free online tech support. You need flyback 259296 for your model. heres the link it cost less than 50 bucks.
    http://servicemanuals.vstore.ca/
I turned on my tv this morning and the power light is flashing and tv wont turn on
if the power indicator flashes three times then goes out and stays out then its usually the power caps which are CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the repair instructions on CD
Aug 08, 2011 | RCA R52WH76 Television
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Digilogic tvcombo keeps cutting out
probably got a bad capacitor in power supply
Sep 07, 2009 | RCA R52WH76 Television
Tv won't come on
Typical reset sequence is: unplug the set, press the power button a few times ( Yes, with the set unplugged ). Then, hold the power button down and at the same time ( maybe with your other hand ) plug the set in. If that doesn't do it, there may be a button marked reset on the back of the set. If there was a lightning strike nearby, your set is probably toast. The antenna or cable brings it into the house.
Dec 26, 2008 | RCA R52WH76 Television
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Sanyo tv chassis 2111 Series EB5-W Dead
hi there, light flashes means a shorted parts at the power supply and mostly at the horrizontal sec,, it may need to check-up and repair., do some testing and check-up at the horrizontal section. ty
Mar 10, 2008 | Televison & Video
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
TV keeps turning off.
could be a couple of things
first i would guess to be convergance ic then IC831S (STR-X6456).and could be loose connection.
you could try this to narrow it down, purchase a can of freeze at radio shock and spray it on these ic one at a time see if it stays on longer or just replace them
Dec 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
