Loud knocking noise at end of spin cycle
We have a 5 year old Kenmore 22622 washer that has been making a loud knocking noise only at the end of the spin cycle (as it's spinning down). It is not unbalanced, and will also do this if no clothes are even in the washer. The washer works perfectly fine otherwise. It does not seem to be worsening either, as it's been doing this for at least a couple years now (always just meant to call someone to look at it, never have). Finally thought I'd just get this taken care of. Any ideas as to what this could be? My 5 year old top load Kenmore 80 model washer started knocking and vibrating and making a boatload of noise at the end of every spin cycle several months ago. I balance the loads and I've checked it and it's level, both side to side and front to back. It makes the noise whether its full or empty, and it still works, but I fear it will self destruct each time I run a load of laundry. My dilemma now is "Do I... 1) pay the $65 plus whatever it costs the repairman to fix it, 2) do the special deal thing for $215 where they fix it and guarantee it for a year, 3) kick it to the curb and buy a new one or 4) hope that someone out there has had the exact same problem and has actually fixed it? If I had a better idea of whether it was going to cost $30 in parts or $300 in parts, I'd have a better chance of making a good choice. Can anybody help???
  • 868 Answers
Have you checked the wire harness ,because the tapping of just 2 wires hitting the cabinet is overlooked alot.The noise just 2 wires makes simulates a hammer knocking inside.If the problem isn't escalating than check to see if your tub support arms are all tight.There are 12 of them.
Posted on Jun 12, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
To allow for unbalanced loads and reduce vibration in the floor of the house, the outer tub is suspended by various means. Some machines use a heavy rubber ring, others use spiral springs but either of those can, after a heavily unbalanced load, unhang themselves or in the case of the rubber suspension, the rubber tires and rips.
If you remove the back panel (10-12 screws) and look inside while pushing the tub side-to-side, you should be able to find the suspension and inspect it with good light.
Apr 17, 2008 | Kenmore 22622 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Loud noise when spinning
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
Aug 11, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
917 people viewed this question
Top Washing Machines Experts
