Question about Sony FD Trinitron KV-32HV600 32" TV
No picture when i turned off the tv, an hour later i could not turn it back on but the standby light was blinking(sometimes 7 blinks at a time, sometimes 6 and 5) but the dvr was still working and recording shows as scheduled. after a day or so it turned on fine. recently the same thing happened. everytime i try to turn on the tv i just get the "standby" light located under the screen blinking. is this a timer or something? After a power cycle I get stand by light blinks 6 times and pauses and repeats the 6 blinks. In the last few weeks it has taken longer for the tv to come on. Now all I get is the blinking light no vido or sound. Can you tell me what the 6 blinks might meain. Thanks Dennis
  • Anonymous Mar 16, 2014
    when my tv turn on it turn back off and standby light is blinking
    Genius:
  • 2,035 Answers
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
if the tv is under warranty you can get it fixed by the company or you need to contact the local service center to fix the issue .
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Posted on Jun 12, 2008
  • 796 Answers
Can you please mention your tv model
  • isaac johny
    isaac johny Jun 12, 2008
    it the thermal fuse which makes the tv to go in standby position..
    you should replace the thermal fuse..to get the tv working again
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My Sony 42" DLP TV blacks out every 87 seconds. Then the green standby light blinks 30 times then I get picture and no sound. 7 more blinks after that I get sound. In 87 seconds later, it blanks out again...
Please replace Lamp in TV because this lamp is weak in result, causing darker picture and turning off and on TV.
Lamp replacement procedure would be written in user manual and its easy.
I would recommend to buy Sony original replacement lamp for TV safety.
Thanks.
Nov 13, 2009 | Sony Televison & Video
My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Standby light blinking
How many blinks is the light blinking in between pauses?
Sep 24, 2007 | Sony KP-51WS520 51" Rear Projection...
Sony FD Trinitron KV-32HV600 32" TV Logo
551 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
