Question about Asko D1716 Built-in Dishwasher
Asko Dishwasher 1473 - 262
Hi, I have a Asko "Superior" dishwasher, type, 1473 - 262, the problem is, When the machine is first started, it produces a fluctuating sound, and no water is entering or draining.
Something is operating but sounds only running at half capacity, if you can help, I would be very grateful. Cheers Brian.
My Email address: warbel@gmail.com
My Asko 1473 Washer will not open after it went through the wash cycle.The lock doesn't release.How do I open it?
Posted on May 03, 2010
Sounds like you need to replace the water inlet valve. I'm already on my second after only about 4 years of use.
Posted on Sep 03, 2008
  • 868 Answers
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Posted on Jun 12, 2008
Dishwasher Drains, Fills but won't wash
It sound like a water switch level problem. I am not familiar with your specific dishwasher, but there are 2 types of level switches. 1)A diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. 2)Floating switch that located inside the dishwasher's bottom and operate a switch. In case there is a floating switch in your dishwasher - check for its smooth movment and check as well the switch by a multi-meter (an on/off switch). Defective switch should be replaced. If level switch in your dishwasher, is a diaphragm device - Open the rear panel, find the device and clear first any obstruction in the tube.In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it will not react, you should replace it. Good luck !!
Jul 16, 2007 | Asko D3112SS Stainless Steel Dishwasher
ASKO dishwasher won't drain and makes rattling sound.
I had tried several failed attempts to fix this problem. Finally I got on my knees and asked God to make the dishwasher run in Christ's name. The dishwasher just completed it's first cycle without any problems.
Feb 10, 2009 | Asko 24 in. D3121XL Free-standing...
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Jun 30, 2008 | Asko D1716 Built-in Dishwasher
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Asko D1716 Built-in Dishwasher Logo
721 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
