Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
LSQ9520LQO Top loading washer
Washer fills and agitates but wont drain or anything else. Not even when the dail is moved, unless you start back at agitate. It just won't work past that. I already replaced the timer.
  • 3 more comments
  • Anonymous Aug 03, 2008
    Solution to bypass the switched worked GREAT! I started to research buying a new washer but decided to goggle "whirlpool washer troubleshooting" and up you pop. THANK YOU!
  • Anonymous Mar 20, 2009
    everthing runs well untill it reaches the rinse cycle, then it doesn't want to spin my clothes
  • Anonymous Mar 15, 2014
    washer is filled and hear whining sound but agitator does not move?
  • Anonymous Mar 16, 2014
    fills and drains. can move top of agitator with hands but not bottom
  • Anonymous Mar 17, 2014
    when I start a load, the washer sounds like it's draining but then it doesn't do anything else and I can't shut it off either
  • 5,911 Answers
It sounds like you have a defective lid switch. This is a typical symptom when the washer stops when it gets to the rinse cycle and won't drain. You can check by opening and closing the washer lid and listening for a "clicking" noise as the lid switch activates. The switch is located on the right hand side of the wash tub opening and is activated by a plastic piece on the lid (called a lid strike) through a small hole. You also attempt to use a small screwdriver and push down on the lid switch contact through the hole to see if the switch will make contact. Typically the switch either comes loose, the lid strike breaks off, or the switch breaks. If you diagnose the problem and it turns out to be the switch, you can use the following link for instructions on how to replace it:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Replacement parts can be found at searspartsdirect.com. Just type in your model number and your part can be found under the "Top & Cabinet" heading on the next page as item 11 (part #3949247). The lid strike can be found under the same heading as item number 20 (part #358684).
NOTE: You do not have to drain the wash tub to replace the lid switch. The switch repair does not require you to move the washer. Let the washer to the work. With the switch replaced, the washer should drain on its own by placing it on the SPIN cycle. You can also make a by-pass by using the old lid switch. With the old lid switch removed, simply cut the white plug off the end of the switch, leaving about an inch or two of wire (This is the connector that's attached to the SWITCH, NOT the timer!). Cut the middle wire flush and splice the two remaining wires. You now have a by-pass that you can connect to the timer plug to drain the washer. This will also enable you to use the washer until your part arrives. CAUTION: It is not recommended to leave the washer in this state, as the tub will no longer stop when the lid is opened. You will have to stop it by manually pushing the timer in, or wait until the timer completes the full wash cycle.
If you do not wish to order parts online, use the part numbers provided and take to your local applaince parts retailer. I hope you find this information helpful. Please post back if you have any questions, or require further assistance.
Posted on Jun 12, 2008
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washer fills, but doesn't do anything else
if it fills then the power is there open the lid and make sure all connectors are on to the timer if they are then more then likely u have a motor problem check carbon brushes if these are low then the motor wont turn the drum if there is no carbon brushes ull have a module if this is faulty most of the time its cheaper to replace the washer m8
Aug 28, 2007 | Danby DWM99W Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
272 people viewed this question
Dan Webster
Dan Webster
prem mathew
