Question about IBM E74 17" CRT Monitor
Problem with my monitor display
When i switch on my system, monitor displays a blue screen or a white screen. If i keepon switch-on and switch-off my monitor it shows either a bright screen or complete dark screen and sometimes to the normal screen we could work on. Please help me with this problem.
  • 65 Answers
1.cheeck VGA cable
2. check any Loose contacts in video section(Neck board)
Posted on Oct 07, 2008
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 09, 2012 | Acer Aspire One D255-2670
I want to know if I can hook up a second monitor to this system?
The HP Pavilion a450n video card does not support 2 monitors. You can hook up a monitor and a TV at the same with the current video card it has. If you wanted 2 monitors you can replace the AGP video card with a new one that has 2 monitor outputs. You will need to get an AGP video card with 2 monitor outputs (DVI or VGA), open up the case, remove the current video card and replace it.
See the HP website for more technical information on this computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00058235&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=392522#N59
I hope this helps.
Apr 26, 2011 | HP Pavilion a450n PC Desktop
I have one whitw and blue line on display of my dell inspiron 1520
Please try attaching an external Monitor to your notebook and if the white line still appears then there is something wrong with your display adapter integrated on your notebook's motherboard if not then its your LCD display. Check your Service Tag in the support and see if your warranty still active so you can have either of the 2 replace.
Aug 18, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
PL2010m displays two colors stays on just blue and white
Sorry, but this sounds like a controller issue. Are you able to open the monitor's menu? If yes, try the monitor on another computer with other cables, if that doesn't help its a internal problem. The only thing you could try yourself is opening it up and reseat all of the cables. If that doesn't help, you should contact a professional or consider replacing the unit.
May 29, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor is on but screen is black. green light for switching it off/on does not do anything when pressed
Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 01, 2010 | Dell E173FP 17" LCD Monitor
I have a dell Dimension 2300 and the images are very dark. I don't think it is from the monitor.
Try these steps: 1. Check the monitor settings. Access the On Screen Display (OSD) Menu System. Adjust the contrast and brightness using the control buttons in the monitor.
2. Run the monitor self test. Unplug the video cable from the computer (cable from monitor to the back of the computer). Usually it has a blue or white connector. Turn on the monitor alone. It should display the self test pattern (white, red, green & blue). If the images are dark in the self test, it is a problem with the monitor.
2. Rotate the monitor to face a different direction. This will help in eliminating sunlight glare which can cause poor picture quality.
3. Test your computer using another working monitor. If the problem occurs in a known good monitor, then it is a video card or motherboard (if your video card is integrated) problem.
I hope these options help.
Jan 19, 2010 | Dell Dimension 2300 PC Desktop
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Display Becoming White
First, to verify if it is your display adapter, connect an external monitor to your laptop and see if it displays fine. If it is fine on the monitor, then we know that it is from your laptop screen(in this case, it is either you first check from a technician if it is the colour that has to be refilled or if you need to purchase a new screen). If not then it is from your display adapter(could be from corrupt display drivers). In this case, you would have to re-install new drivers for your display adapter(you can download it from your system manufacturer's website if you don't already have it).
Thanks
Dec 01, 2008 | Computers & Internet
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
IBM E74 17" CRT Monitor Logo
139 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
