Question about Bazooka CSA150.1 Car Audio Amplifier
Amp turns off after a couple minutes of playing
I have the Bazooka CSA150.1 250 watt amp and a Lanzar 250 RMS/500 watt peak. i can turn my truck on to acc. and the sub will work but when i turn my truck on, the sub will be hitting for only a couple of minutes, then the amp will turn off. But after that, you can turn the truck back on acc. and the amp will run great... what could be causing this?
Thank, Bryant
    Scholar:
  • 71 Answers
That's a new one on me.
The only electrical difference is the battery voltage on ACC is 12 volts. When you start the truck the alternator should put out about 13.7 volts. That would make me suspect a bad power supply in the amp or the output transistors, something in the amp is getting hot at the higher voltage and shutting it down
That would explain why you get two minutes ,and than when you turn the truck off the voltage drops back to 12 volts and the amp comes out of protect mode. Try a amp swap or if it's a self amplified tube, hook it up to a friends system.
Never hurts to put a voltmeter on the battery with the truck running, and off, to make sure the alternators voltage regulator
is not faulty and exceeding the rated voltage.
Good luck, let me know what happens, I'll ad it to the book.
Regards Paul
Posted on Jun 12, 2008
Will the amp blow my speakers?
If you bridge the amp and get 1000 watts RMS and that is split going to two speakers then you will get 500 watts RMS at each speaker. If you have your amplifier on maximum gain it may blow your speakers, not because they are overpowered but because you might run into "clipping" issues running the amp at maximum capacity. Just to be safe I would dial the amp's gain down to 3/4 of the way to full gain. That should give you ample power and keep your amp from clipping and running hot.
Aug 11, 2015 | MTX Car Audio & Video
I have a Boss 4x50watt in-dash stereo, 2 Pioneer 270-watt max/ 40 watt nominal rear speakers, and 2 Pioneer 500 watt peak/ 80 watt rms front speakers. Do I need to buy an amplifier? Or is does the head...
You do not need to buy an amp, the only reason to buy one is if you do not think it is loud enough when you turn up the volume to max. The speakers you have can take more power than your stereo can provide, but you only need to add an amp to get more power if you want it to play louder than it does now.
Dec 19, 2013 | BOSS AUDIO SYSTEMS Car Audio & Video
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
Subwoofer and amplifier wattage problem
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What is the rms for a single max12d lanzar is it 500rms or 250rms
Description One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
Oct 27, 2009 | Lanzar MAX12D Car Subwoofer
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
ELA 500.I
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
Mar 13, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Watts
The advertised wattage for your amp is:
300 watts RMS X 2 @ 4 ohms
600 watts RMS X 2 @ 2 ohms
The actual wattage you will be using will depend on what type/impedence speakers you are using, and how they are wired. Here's a link to some more of the specs of your amp:
http://www.bazooka.com/productAutoAmplifiersRS.asp?id=199
I hope this helps.
Nov 30, 2007 | Bazooka RSA75.2HC Car Audio Amplifier
Bazooka CSA150.1 Car Audio Amplifier Logo
198 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Abubacar Alfredo
Abubacar Alfredo
Level 1 Expert
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
