Question about Sony Playstation 3 (PS3) Console
Play station 3
My ps3 seems to lose contact with the console.and the controller. When I get ready to save or load in my game ( Oblivion ). the controller sometimes wont work unless I plug in the controller if it is not plugged in or unplug the controller if its plugged in.Then it will work great for while and happens again. The controller is fully charged. Is any one else having this problem?
Try to fix that to the repair man until it becomes worse
Posted on Jun 12, 2008
Hi i get an error code of 8001050f when i go to play my video games can you tell me how to fix it so i can play my games
go to the play stations web site to find out what the code means.
if your ps3 has a message of trophy registration error sony will say you need to turn in your ps3 for service this is not true i fixed mine by saving my game data on a thumbstick then deleted the game save data shut off my ps3 then turned the main power (the switch in the back) off for a few minutes to allow the power to dissipate. Then i restarted the ps3 copied my game save data back and my COD modern warfare 2 played like a champ!
i did lose all of my trophies but the game saved data allowed for 12 percent of them to come back apon completing one special op mission.
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
Hi my ps3 wont let me sign in... after like 10 seconds it says an error has accoured and then the error code my friend is also having the same problem
For one, you and your friend can not log into the SAME account, if that is your intentions. If you two are using different accounts then that is a different story.
You might could check out Sony Play Stations website to ensure there console servers are not down for maintenance.
Or you could do a hard reset if all else fails.
Hard Reset procedure for the PS3 Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Aug 22, 2010 | Sony Playstation 3 (PS3) Console
Will not load a saved game from hardisk.
i had a bit of the same problem. For me it would freeze when i was loading them. I ended going back to the last good save and reloading it, deleting the old, and saving new files. Hope this helps.
Mar 22, 2010 | Sony Playstation 3 (PS3) Console
How to change ps3 setting to play ps3 games
create a memory card then selet ps2, then insert a ps2 disc :)
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Play Station 3 wireless controller will not ''link'' to PS3
Play Station 3 wireless (Intec) controller will not ''link'' to PS3 Console
Apr 25, 2009 | Sony Wireless Controller for PS3
PS3 playing Oblivion The Elder Scrolls IV and when I attempt to select continue and it states load complete and I select X to , it goes to the loading screen but the bar where it shows it loading partially...
Sounds like a game bug, either that or this bug only occurs for this particular game disk.. check it out on a different ps3, or like i would do, return it or sell it
Mar 10, 2009 | Sony PlayStation® 3 (60 GB) Console
Update System and Saved Games
then clean the disc take off alll the finger print thats wat happen 2 me
Jul 01, 2008 | Sony Playstation 3 (PS3) Console
Is there any way i can reset my Play Station 3 System?
Greetings RyanMcLean20,
If you want to do a hard reset, here is what I suggest.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/2 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 09, 2008 | Video Game Consoles & Games
Frezzes wen it just loads into a game
Hard Reset procedure for the PS3 (as instructed by Sony CS).
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
Hopefully this will solve your freezing problems.
May 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
