Question about Canon PIXMA MP530 All-In-One InkJet Printer
Loading ink jets
Cant find how to replace ink jets,in printer,plase help.Thank You
  • Anonymous Jun 14, 2008
    ink cartridges need to be changed
  • 2,039 Answers
Go here. Type "replace ink" in the Search window in the center of the screen and click on the Search button. Select "How do I replace or insert an ink tank?", then go to the section for installing the ink tanks.
Posted on Jun 12, 2008
I also ran the alignment tool and the printings are still not focused with slight outline
Hello Shtoyot,
The new style Ink Jet printers include the printer head with the ink cartage, to better trouble shoot the issue by divide and conquer.
If you replace the ink carterages doe the picture improve? this will help to focus down the problem to either the rollers, Paper, or computer.
Thank you
Oct 21, 2012 | Office Equipment & Supplies
My problem is that my printer says i cant print because it says unable to print 6A
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 17, 2011 | Brother MFC-990CW COLOR INK-JET MFC Ink...
It keeps showing the message "remove and check the right ink cartridge". we already removed and re-install it many times. we also cleaned it and we still show that message. help! thank you!
Try to replace the ink cartridge with a new name brand ink jet cartridge that matches the manufacturer. Sometimes aftermarket ink jet cartridges don't work as well as the name brand ones.
Dec 18, 2010 | Office Equipment & Supplies
Wont print red ink
There is no master on the drum. you need to make a master.
May 25, 2010 | Riso RZ390 Duplicator
Hp G85xi ink jet printer. Keep getting the
Possible your printer is equiped with by optical sensor of the determination to density of the paper. If he was littered by dust, that you it is necessary to clean his(its) compressed by air.
Mar 06, 2009 | HP G85xi All-Color InkJet Printer
Nukote Black Ink Jet Replaces HP21
clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
Driver
deseo tener los drivers de la impresora canon S200x
jomuroj@gmail.com
Jan 01, 2008 | Canon S200X Ink-Jet InkJet Printer
HP 610 C inkjet printer
i have a laptop full of usb ports ,for that i have purchased parallel to usb port to suit to printer and laptop but iam unable to print .laptop is asking drivers
Nov 18, 2007 | HP DeskJet 610c InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
old marine
old marine
