It will actually work, however,
you will not be able to dock the iPod® Nano into the JBL On Stage™.
You can connect the audio in cable to the headphone jack of your iPod. That's the only way, hope this helps. Pls rate solution. Thanks!!
Comments:
Jun 12, 2008
- By the way what you need is a A stereo mini jack connector for Ipod Nano
Jun 12, 2008
- Where to buy it, just check this link and enter your info click Here
Jun 12, 2008
- If your product is still within the warranty call JBL support line incase you want to inquire for replacement. Thanks for using fixya!!
Nano 3 rd generation is not compatible with the JBL on stage dock , you need to buy compatible dock to listen to music or if brought this you can get it exchanged to another dock which is compatible with the nano 3 rd gen..........
good luck...................
Comments:
Jun 12, 2008
- Please check JBL device works with other compatible device.................
Jun 13, 2008
- Try using the batteries on your dock and power it on and even check its on which connect to power adapter this could even fault in the power adapter .............if did not work you need to contact if under warranty or if out of warranty you can give it to a local service center and it fixed..............
I have a JBL on Time I pod Dock / Radio. The I Pod dock had broken away. Can it be reatached and if...
(More)
I have a JBL on Time I pod Dock / Radio. The I Pod dock had broken away. Can it be reatached and if so by who?
My jbl stage micro speaker will not play music. The iPod will charge, but no music is coming from...
(More)
My jbl stage micro speaker will not play music. The iPod will charge, but no music is coming from the speakers.
ipod does not charge - both ipod and speakers are new. Ipod is 160Gb classic. Ipod charges when...
(More)
ipod does not charge - both ipod and speakers are new. Ipod is 160Gb classic. Ipod charges when connected to PC. Thanks in advance! Bernie
When I put up the volume on the speakers too high, an orange light comes on instead of the green one...
(More)
When I put up the volume on the speakers too high, an orange light comes on instead of the green one and it makes a loud vibrating noise so I can't hear the music. What do I do?
I accidentally plugged my external hard drive cord into my jbl on stage micro speaker dock (the cord...
(More)
I accidentally plugged my external hard drive cord into my jbl on stage micro speaker dock (the cord fits both) and think I shortcircuited the speaker (i.e. it won't turn on now). Is there any way to fix the speakers or are they dead now?
