Question about JVC AV-27530 27" TV
Connection problem trouble connecting jvc tv with vcr
  • 85 Answers
MAYBE YOUR CONNECTING JACK IS CORRODED,FLOATING TO ITS TERMINAL.THEN YOU MAY COLDSOLDER THE TERMINAL OF YOUR JACK
Posted on Jun 12, 2008
Connect jvc dvd to zenith tv
just hooked up with an rca cable from the output jack ( audio/video ) of your dvd recorder then the other end connect to the input jack of the tv. then set your tv at the same time the dvd player to record.
Aug 11, 2012 | JVC DR-MV150B DVD Recorder/VCR
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
What tuner for dvd/vcr combo JVC DRMV80B?
First you must connect the antena cable on JVC dvd/vcr ant in and from ant out of jvc connect to TV ant in. Then you must find TV programs on JVC.After that you can record a program and watch another. Be careful you record the program which you find on your JVC.
Mar 11, 2010 | Televison & Video
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
How can I connect my tv to my vcr using rca connector ? My VCR is old and only records up to channel 44.
if your old vcr have a rca jack at the back, then you can easily connect your rca. remember color yellow means the video and red and white means audio left and right. but if there's no available jack then you have to connect it using RF connector directly connected to the antenna connector at the back of your tv. then you need to rescan your tv to get the exact channel for your vcr. good luck!
Aug 20, 2009 | JVC Televison & Video
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
Jun 24, 2008 | JVC Televison & Video
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
Camcorder to JVC HR-A592U S-VHS VCR
you must select the input in your vhs. usually its a line input (wether 1 or 2). try to find it also using your supplied remote for the vhs. good luck!
Feb 09, 2007 | JVC HR-A592U S-VHS VCR
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | JVC HR-S3901 S-VHS VCR
JVC AV-27530 27" TV Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
