Question about RCA P61960 61" Rear Projection Television
Clicks on and off
Have to click power on over and over sometimes it will stay on for a few seconds sometimes a few minutes but will eventually go out. i can hear a click when it tries to come and another click when it goes out also when it does stay on it takes a while for the picture to straighten out
    Guru:
  • 1,894 Answers
Its due to realys
Posted on Jun 12, 2008
  • dewan nafees ahmed Jun 12, 2008
    the click sound is due to relays.
    they switch every time there is some kind of short circuiting in the circuit.
    these relays protect your unit from damage of other components.
    and hence u can find where the shorting is occurring.
    else make it found by a tech.
    this is how you fix this thing.
    hope it helps you.
    please dont forget to accept the solution if u go by it.
    thank you
    have a great day
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
Apr 22, 2014 | Whirlpool Cooktops
Clicking sound when you turn the tv on but won't work until a few minutes sometimes longer .
The clicking sound is an indication that the power supply is trying to start but is failing
Apr 16, 2013 | Televison & Video
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
KORG C-303- power doesn't always connect or cycles off and on
The contacts MAY be bad in the switch, in spite of it "clicking".
Test the switch with a continuity tester.
Oct 17, 2009 | Music
Motor clicks on for a second then clicks off
Sound like a bad thermostat, otherwise it is a sick puppy. I clean mine with compressed air, or a shop vacuum on 'blow'
Nov 28, 2007 | Samsung RB215LASH
RCA P61960 61" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
