Question about Motorola Mobility RAZR V3c Cellular Phone
Backlight behind numbers
My backlight behind the numbers goes off after the phone is turned on. It stays lit just long enough for the menu screen icons to come up then it goes off and does not come back on. Please help
  • 61 Answers
In the case of your phone, you have to replace the keypad membrane of your phone, if you cant find a spare keypad membrane, you have to replace the whole flex. you can buy a flex in motorolla service centers near your place.
Posted on Jun 18, 2008
Vizio Model SV320SVT powers on, after Vizio splash screen it goes blank. Power stays on, but no backlight on screen.
Yes its very repairable as long as the logo stays white you can assume the main boards good. I would recomend contacting the people at www.tvrepairworld.com by hitting the contact us button from their website. They will be able to assist you in finding out whats happening with the set for free. They have most parts available as well.
Aug 07, 2012 | Vizio SV320XVT 32 in. TV
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Right now, my laptop screen is black. I can hit Fn
I'd guess that it's the CCFL (backlight bulb) going bad. What points me in this direction is that you mention that the backlight (when you're able to get it to turn on) isn't producing bright white light (and pink is one of the colors that normal fluorescent tubes produce when they're failing). You're in luck because CCFL backlighting isn't the most difficult thing in the world to replace (if you can handle delicate electronics) and you may just be able to hack together some LED backlighting for yourself while you're at it. There are a few reasons that LED backlighting is better than CCFL but the most important is that LEDs last pretty much forever.
There are a number of video tutorials on YouTube about replacing the backlight of an LCD display and a few of them detail the installation of bright-white LEDs in place of CCFL backlights. If soldering and math aren't your strong suits a drop-in replacement for the CCFL tubes should be fairly easy to find online...
Feb 06, 2010 | Acer Extensa 5420-5687 Notebook
I was chaging setting and I turned of backlight
If its just the backlight then you can stay in a well lit area and look at the screen that way to change the setting, also you could try plugging it in to keep the backlight on.
May 19, 2009 | Nokia 1600 Cellular Phone
Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
Problems when it rings
You should be able to control how long the display light stays on. Try going to the menu and select Settings. I don't have the exact phone, but in the Settings menu you should be able to select Display. This is typically where you can control the backlight and length of time it stays on. Good Luck!
Oct 18, 2008 | Motorola Mobility RAZR V3
Backlight on external screen
take it to a mobile tech n have them fix it for you or you can just extend the personalise settings
May 19, 2008 | Motorola Mobility RAZR V3m Cellular Phone
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
