Tv code i have a toshiba 27" dont have the original remote from tv. I trying to find the manufacture code for this model to program the tv.
  • 85 Answers
YOU MUST BUY UNIVERSAL REMOTE,GO TO THE MENU OF YOUR TV AND SET THE PROGRAM OF YOUR TV TO THE REMOTE.
Posted on Jun 12, 2008
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
Dec 15, 2012 | Toshiba 32A33 32" TV
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
I dont have the origional remote to my 27AF44 toshiba tv and i need to get to video/tv mode. i need to know how to do that or what is the universal remote code for this tv?
Ur tv have manual button that said VIDEO on the tv frame bazel.Push that VIDEO button u will get into Video 1 or 2 modes.Tries the tv manual buttons Channels up or down buttons like a few times,some Analogue tv models will let u to get into Video modes that ways.Not try website like Remotes.com to buy the tv original remote to used.This video modes funsctions are optional for tv useages for most or all of the tvs universal remotes.Tvs universal remotes are basicly only work for like for a power buttons on/off,channels up/down and volume up/down that it not more.
Aug 19, 2011 | Toshiba 27AF44 27" TV
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
I have a JVC AV-27120. Just purchased a new remote but the TV codes that came with the remote user guide dont work. What is the 3 digit code for my TV to program the new universal remote?
The codes in the owner manual don't work not any codes out here will help u.Return the universal remote.Try website like Remotes.com to buy an exact remote as original remote,might have some new JVC codes u could tries,but not likely it will work either.
Feb 02, 2011 | JVC AV-27120 27" TV
I'm having trouble with my 27AF43 toshiba remote. I've changed batteries it will only raise and lower the volume. Can I buy a universal remote but I don't have the programming code for the tv.
HELLO
Sounds like your RC unit is on the way out! Get on the net, punch in your make & model of TV to find remote controls. There's bound to be a generic remote will operate all functions as opposed to some universal types of control.
I am convinced you will find one - possibly even an original!
Hope this helps in some way.
Apr 20, 2010 | Toshiba 27A43 27" TV
How to program one for all remote control on a sanyo tv
You can find the most up-to-date list of remote codes at One-for-all's site here. Just be aware that on some models of TV, a universal remote may not support all the functions of the manufacturer's original.
Hope this helps, and thanks for using Fixya!
Jan 31, 2010 | Sanyo DS27800 27" TV
CANT GET TOSHIBA CT 90302 TO PROGRAM
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Sep 01, 2008 | Kenwood RC-R0720 Remote Control
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
