Maxtor BASICS  Personal Storage 3200 (U01H500) 500 GB USB Hard Drive Logo
Posted on Nov 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to hook my external hardrive up to my Mac and seem to have misplaced my manual. I need specifics on which cables I need to hook up, etc. Is there information online and/or a picture of this so I can see the configurations? If not can you give me specific information so I hook it up correctly? Thank you for any help!
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Nov 02, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557623
Points
31058
In general, external disk-drives have one USB cable, running from the unit to any USB port on your computer. The smaller external enclosures have a "laptop" disk-drive inside, which draws electrical power through the USB cable. The larger external enclosures have a "desktop" disk-drive inside, and requires an external AC 110V adapter, which connects to a power-jack on the enclosure.
Manual or diagram showing how to hook external cables back in correct place
Did U meant to hook the cable to keyboard,mouse etc back to the backplate?? or the cable on the motherboard itself?? i cant get your questions enough..please be specific..TQ
My hardrive is plugged into my mac, the light is on, the hardrive is spinning, but no icon shows up on my desktop. I've searched my computer, and the icon isn't anywhere. I don't know how to access it...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
I'm trying to hook up my Westinghouse L2410NM 24 inch monitor to my MacBook Pro. I'm using the DVI adaptor for my mac to connect to the monitor via an DVI-HDMI cable. My mac seems to detect the L2410NM,...
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
1helpful
2answers
I have a Seagate External 500g hardrive and I need to down load the mac driver. My computer is a Mac Book Pro 15". Can you tell me how to do this? It says on box to go to www.seagate.com but I can seem...
I called apple about this and they said there is no mac driver, that a mac should read a seagate external hard drive without any driver. My file system was ntfs.
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
I dont understand how to hook up my old hardrive to the sabrent hardrive enclosure
Open the enclosure, plug the IDE cable into the back of the hard drive. Plug the power connector into the back of the hard drive. Mount the hard drive with the included fasteners. Close the enclosure, Plug in the power supply to the wall. Turn on the external drive. Plug in the USB cable to your computer. Browse your files.
Need to dump my data from my mac to my maxtor external hardrive
you need to backup your system using windows back utility on your computer and save the files to your external hard drive.
Good Luck
2answers
External Hardrive crashed
Try reading this post........http://forums.macosxhints.com/archive/index.php/t-32880.html
Dvd/vcr player is hooked up but not playing...
Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
