Question about Macally BLUEWAVE Wireless Headset
BlueWave Bluetooth sending unit to wireless headset model FCC ID:MQ4- BSH202
When my headphones were working perfectly, the LED color was blue. It stopped working and the LED color is now pink. I can't see a problem with the headphones because when I put the switch on, the green light is on. Should I send it back to Kelly Co. in Florida or to you? I'm in Canada and likely it would be very expensive to send back. Do you have any suggestions that I could do at home about the problem? It should still be under warranty because it's less than a year since I bought it. I use only Duracell 1000mAh rechargeable batteries. I've also tried with alkaline batteries and it's still the same problem - a pink light and no sound.
  • genazing Aug 03, 2008
    I have the exact same problem that the previous person described. My headphones worked perfectly and then the sound started cutting out and now my LED light turns either pink or red when I turn it on. The color changes. I've been trying to switch batteries to see if it will work, but it only changes the color of the light from red to pink or pink to red.
2 Suggested Answers
  • 10 Answers
SOURCE: blue wave wireless headphone
Please take out the batteries from the dongle and headset for 20 minutes.
Insert a new battery into the dongle, plug into your player and turn it on.
Wait for 2 minutes, insert another new battery into the headset and turn it on.
It will take about 2 minutes to connect each other at first time.
Posted on Jan 03, 2008
  • 10 Answers
SOURCE: Bluetooth music headset won't boot
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
Hi, I buy a new Plantronics Backbeat 903, but right now it's unrecognizable by any movile, can you give some hints on how to fix that problem. I try with an LG P500 and Nokia 6110, no answer...
Delete the device from the phone, then re-pair the headphones with the phone. If you just turn on the headphones, the device cannot connect because the headphones store the information that you already deleted it on the phone. To pair again with the other device (like a computer, phone, etc) you need to turn off the headphones, then turn on the headphones but press the power/pair button and hold until the led flashes red and blue (like 10 sec after the led turn only blue) to put it in discovery mode. Then turn on your phone and follow the instructions for finding (discovering) your bluetooth headset.
Good luck from Headsets Direct!
May 06, 2011 | Plantronics Backbeat 903 Bluetooth...
Paring gnx bluetooth headphone
Press power (small triangle) and vol up (small thin button on the side near the led light) buttons together for 4 seconds until it goes red/blue for pairing (up to a min). Passcode is 0000.
Sep 13, 2009 | Samsung SBH170 Stereo Bluetooth Headset...
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
How do i pair my bt4517 headset?
you need to switch on the bluetooth on your mobile. then switch on the headset (by holding the call button for few second). you will see blue light flashing. now to pair them with ur mobile click the volume controls (+ and -) on heatdset together for two second and search for the bluetooth head set in ur mobile it will detect it as BT*** just give the pass code 1234 and there you go. hope this helps. the instruction is there in the box!!!
Got this elsewhere - tried it - it worked !
Jan 31, 2009 | Macally Bluewave BlueTooth Wireless Stereo...
Blackberry 8800 headphones aren't working
The 8800 does not support the stereo function on headphones.
Here is the ATT thread: http://forums.wireless.att.com/cng/board/message?board.id=rim&thread.id=22479
Jun 06, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
Blue wave wireless headphone
Dec 14, 2007 | Macally Bluewave BlueTooth Wireless Stereo...
Oct 20, 2006 | Macally BLUEWAVE Wireless Headset
Macally BLUEWAVE Wireless Headset Logo
257 people viewed this question
Top Macally Radio Communications Experts
eradiostore
eradiostore
Are you a Macally Radio Communication Expert? Answer questions, earn points and help others
