Question about Frigidaire GLTF2940ES Front Load Washer
Fabric softener will not go into the washer from the dispenser drawer. How do I correct the problem?
    President:
  • 1,294 Answers
Plug off the wall. Open the top of the machine; check to see if the 3 tubes are well connected to the dispensing drawer. If possible you can dismantle your drawer to see if anything is clogging it. Clean out well. Refer to users' manual, may find something useful there.
Posted on Jun 12, 2008
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Fabric softener dispenser/how to clean
Good Morning Friend,
I understand you want to know how to clean the fabric softener dispenser from your Frigidaire washer, model# ATF7000ES. To remove the drawer and clean the dispenser, please do the following:
• Remove the drawer by pulling it out until it stops.
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softener residue may indicate improper dilution or more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residues from the upper and lower parts of the recess.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    Fabric softener not draining
    Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
    May 23, 2009 | LG WM1814CW Front Load Washer
    Kenmore front load washer will not dispense fabric softner
    I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
    Oct 28, 2008 | Washing Machines
    Detergent and fabric softener dispense at the same time
    Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
    Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Frigidaire GLTF2940ES Front Load Washer Logo
    124 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
